BigJimnyMeet 2024
Towing a caravan
- Thank you received: 552
06 Sep 2021 18:23 #238292
by Scimike
Replied by Scimike on topic Towing a caravan
Its true what Lambert said, for its size the Jimny can tow quite a lot. So I will sing its praise for this, my main issue is simply lack of power.
So what's it like:
Put four people plus luggage in your Jimny and fit an arrestor parachute and go for a drive, it's going to be like that
I get passed by everything on the motorway, even the slow lorries. It just can't go any faster, it's giving 90% to pull at 50, nothing left in reserve.
Hopefully the extra cc the G4 has will help, but you are planning to tow 250Kg more than me so it could be a similar experience.
Nothing wrong with this so long as you are happy to be the slow chap.
My Citroën 2ltr Xantia SR, now that could tow!!!
So what's it like:
06 Sep 2021 20:35 #238294
by Busta
Replied by Busta on topic Towing a caravan
If it's giving 90%, then you still have 10% in reserve
The nice thing about petrol engines is you can shift down a gear and gain power without losing speed. When I still had a 1.3 I'd often be in 3rd to hold 60mph up a long hill.
- Thank you received: 1761
07 Sep 2021 03:28 #238297
Replied by Lambert on topic Towing a caravan
If yours is having to give 90pc towing 750kg then something is wrong. Towing 1300kg I have way more than half throttle left on the flat in top gear. It takes a hill with a gradient marker to get either of mine to slow down.
- Thank you received: 71
07 Sep 2021 07:17 - 07 Sep 2021 07:24 #238300
by lightning
Replied by lightning on topic Towing a caravan
Well, in the end l've got my Defender 110 if the Jimny struggles, that will tow anything.
But it would be great to have the Jimny to use while on holiday, plus it's a lot quieter on the motorway and better for long journeys.
lt will be interesting to see how the Jimny Gen 4 gets on towing a 1,000kg trailer. From the comments already made l fear that hills may make us unpopular with other motorists but time will tell.
Even the Defender was slow on hills when loaded up until l had the engine remapped, now it is much better, sadly you can't remap a Jimny as it only really works on vehicles with a turbo.
Last edit: 07 Sep 2021 07:24 by lightning.
07 Sep 2021 08:14 #238301
by Scimike
Hi Lambert, crossed wires here, simply trying to put across in words how it feels rather than actual figures. 90% is a reference to how much power it feels it is using power rather than the accelerator position, which is about 50-60% on the flat. Just did not want to give the impression you have plenty in reserve as you dont.
Sadly if something was wrong I could fix it, but the engine is in tip top condition and as good as it gets.
I also have a Land Rover Series 2 and to put it into context the Jimny is my preference to tow my caravan. Happy towing in your new caravan venture, sure you will enjoy if you just take your time and ignore the buzzing euro box behind!
07 Sep 2021 09:48 #238305
Have you calibrated your throttle cable? I have found them on occasion to be almost 3 or 4 turns out depending on the age of the car.
08 Sep 2021 07:22 #238329
by lightning
l know what you mean about the vehicle being at "90%"
So you might only have the gas pedal half way down, but if you floored the pedal there's almost nothing in reserve.
Now the missus wants to look at the slightly larger Swift Basecamp 4 caravan rather than the Basecamp 2.
Thats another 100kg of caravan weight, taking it nearer 1100kg empty.
l wouldn't want to tow that with the Jimny, as it's approaching the weight of the vehicle.
The Basecamp 2 is under 1,000kg
08 Sep 2021 08:25 #238333
I happened to notice that there is a basecamp a couple of streets away from my house. It's a lot bigger in person than it looks in the pictures. Windage is going to be a much bigger issue than the actual weight they're quite a big frontal area.
08 Sep 2021 08:29 - 08 Sep 2021 08:30 #238334
by Scimike
Cool, that's what I was trying to put across rather than actual positioning of things.
You need to allow 200-250kg for all the junk that gets added, that's before the pedal cycles and tennis sets get thrown in. My van is 550 empty, but I have 230kg of added extras taking it very close to the 750kg axle limit, all measured on a local weighbridge.
If you read the G3 manual Suzuki recommend a limit of 450kg braked. However, a tow what you want statement upto the gross vehicle train limit (within local laws) and you arrive at the 1300kg printed in on the V5 for a braked limit.
Great for a small car, but I also would be uncomfortable pushing the little fella this hard.
But worth a go, you may be happy and you always have the Defender as a back up.
Last edit: 08 Sep 2021 08:30 by Scimike.
- Roger Fairclough
- Thank you received: 194
08 Sep 2021 08:44 #238335
by Roger Fairclough
Replied by Roger Fairclough on topic Towing a caravan
As a matter of interest, the limits, auto or manual, on a Gen.4 are:-
Braked 1,300 kg.
Un-braked 350 kg.
Roger
Braked 1,300 kg.
Un-braked 350 kg.
Roger
08 Sep 2021 09:05 - 08 Sep 2021 09:12 #238336
Except. When you read the construction and use regulations as amended then it clearly states that a vehicle can tow upto half its kerb weight unbraked to a maximum of 750 kg. So in the case of a gen3 that is something like 550kg give or take. Or 200kg more than the manual states. However the manual also stipulates that local laws take precedence. So by that token the gen3 has to have met the requirements of construction and use in order to be sold here. It can't be both. It's either as the manual and 350kg/450kg or it's construction and use and 550kg/1300kg. Personally I will stick with the regulations until I am forced not to.
Last edit: 08 Sep 2021 09:12 by Lambert. Reason: Clarification
08 Sep 2021 09:06 #238337
Sorry I get a bit ranty on this subject because there is too much contradiction.
Time to create page: 0.176 seconds
