BigJimnyMeet 2024
Towing a caravan
- Thank you received: 70
04 Sep 2021 11:54 - 04 Sep 2021 12:09 #238208
by lightning
Towing a caravan was created by lightning
Has anyone towed a caravan with the new Jimny? lt gets one star out of five in a tow car review!
We are looking at buying a small lightweight caravan (Swift Basecamp 2) and it's around 1,000kg which is well within the Jimny's braked towing limit.
The review says it's unstable and not great, but other reviews of the Jimny say it's terrible on the motorway, which is far from the truth.
Okay, it's not a Discovery 4, but if you've tried towing a caravan with the Jimny, how was it? One thing, l am guessing performance could be marginal towing 1,000kg.
We could fit a caravan stability device if it's got a tendency to be unstable.
We could always use the Defender for towing, but it would be great to have use of the Jimny while on holiday.
Last edit: 04 Sep 2021 12:09 by lightning.
- Thank you received: 1755
04 Sep 2021 12:08 #238209
Replied by Lambert on topic Towing a caravan
I tow a lot with my gen3 and as long as you accept it can be quite slow progress up big hills then you will be fine. The caveat there is that the windage on a caravan is going to be quite noticeable compared with a livestock trailer but equally you won't have any issues with your load moving about as you drive. The additional power of the 1.5 will also help.
The following user(s) said Thank You: lightning
04 Sep 2021 12:12 #238210
by lightning
Replied by lightning on topic Towing a caravan
04 Sep 2021 12:39 #238211
Doubtless written by yet another reviewer who hasn't driven the car let alone with a trailer on. My 9x5 tandem pulls perfectly on the back of Temeraire even at full capacity. 50 mph on the flat is perfectly smooth and stable hills are OK with momentum unless they're really steep or long but with the automatic gearbox it's much easier if a gear change is required. Don't get me wrong it's not even remotely as effortless as towing 3 tonnes behind leviathan but it's no chore. That said I have been towing trailers since before I had a licence so I know what to expect, if it's your first venture into towing then I might suggest a few days practice with the defender to learn the trailer first might be a good idea.
04 Sep 2021 13:08 #238212
Just looking at the van in question and I would like one myself, ideal size for the Jimny, big enough without being a glorified camping trailer.
04 Sep 2021 13:17 #238213
Looking further the nose weight is a little high but being a single you could ballast that away. You will also definitely want extended mirrors as it apparently over 7ft wide but most of them are nowadays.
04 Sep 2021 19:16 - 04 Sep 2021 21:31 #238218
by lightning
Thank you for the advice.
Do you know if the Jimny stability control will activate to assist when towing a caravan, if the outfit gets into a sway?
Last edit: 04 Sep 2021 21:31 by lightning.
- Thank you received: 551
05 Sep 2021 17:13 - 05 Sep 2021 17:38 #238246
by Scimike
Replied by Scimike on topic Towing a caravan
The truth is, as much as it hurts me to say this, the Jimny is not a good tow vehicle. Yes it can do it, but so can my 2CV (yes it has a tow hitch). That's my point, just because it can does not make it good.
The G4 addresses one issue which is a real lack of power, but I can't comment by how much that 200cc will help. Any sort of hill is going to see 4th/ 3rd and 40mph max, motorway speeds 50 / 55 on the flat. Stability is not an issue, it always feels in control (at the above speeds), but the fidgeting nature of the ride is double as you now feel every jolt of the road.
This is my G3 with no more than 750Kg on the back.
This is of course just my opinion, based on the many miles I tow my caravan with my G3.
In fact on holiday now, 360 miles just completed.
I put up with the poor towing experience as I simply like the Jimny, just wish I had 2ltr and a turbo for the days it has the van attached.
Proof a Jimny can happily tow a caravan or load, braked upto 1300kg. Enjoying the journey is down to your expectation.
Summary
Yes it can tow a caravan.
Lack of power is the main issue, at some point you will be travelling slowly on a fast motorway.
50mph is about it on the flat.
Stability is not an issue, its very good if you load the van correctly.
Summary
Last edit: 05 Sep 2021 17:38 by Scimike.
- Roger Fairclough
- Thank you received: 193
05 Sep 2021 21:16 #238260
by Roger Fairclough
Replied by Roger Fairclough on topic Towing a caravan
That's a new one, a fast motorway
, most in my neck of the woods are controlled from overhead gantries and those that aren't are gridlocked anyway. But, coming back to the main point, tow a caravan and you are restricted to a max. of 60 mph so doing a max. of 50 in the inside lane is not such a bad idea.
Not so sure about being overtaken by an artic. though.
Roger
Roger
05 Sep 2021 21:29 #238261
by Busta
Replied by Busta on topic Towing a caravan
I regularly tow with my Jimny (gen 3 manual, 1.6 swap, auto diffs)
and with a balanced 1,300kg load in a single axle 8'x4' trailer it is very stable. Given the size and weight of the car, I'd say it tows exceptionally well. Your issue with the caravan will be the sheer size of it. Extra wind drag will sap power and also make it less stable. A 7ft wide trailer behind a 5ft wide car is not a good combination in my mind.
- Axholme Lion
- Premium Member
- Thank you received: 10
06 Sep 2021 08:42 #238270
by Axholme Lion
Replied by Axholme Lion on topic Towing a caravan
I have an Ifor Williams P5 trailer and used it to tow a few loads of heavy 100 old bricks. About 140 bricks per load. It was sat down a little but it did ok. Just take it nice and easy and don't do anything silly.
06 Sep 2021 09:32 #238272
You might find a better tow car for the money but you won't find one for the size apart from maybe a super short ibex.
Time to create page: 0.170 seconds
