Rustproofing.
- Andy2640
- Visitor
Hermetically seals the surface.
Proven to last 10 years as an anti seize grease on bolts in sea water.
Economical to use
Eco friendly.
Smells like lamberts farm yard
Is even food grade safe with some lanolin products (Prolan being one of them).
Used by militaries and farmers the world over. New zealand farmers love the stuff.
Will not jet wash off with commercial jet washers.
Dries to a semi hard resin (prolan).
Easy to apply, brush on or spray bottle or compressor, all work fine.
Use on electrical connectors, battery posts, the works, is dioelecttric, non conductive.
The Vikings used it on there ships, metal works and leather!!
Supports farmers Baaaaaaaa!!
Can be applied to light rust, eliminating the oxygen needed for corrosions progression.
Apply safely, no mess to worry about, drips in your hair and eyes, no problem.
No thick, smelly, horrible black oil to deal with. Seals for years and stays on no matter what.
One of the best natural anti corrosion products available in my eyes.
LOOK I EVEN EAT IN ON TOAST.
This is their thick pure lanolin grease. I use this on electrical connectors and battery terminals and my radious arm bolts. An amazing anti seize grease.
I used a lanolin called 'Prolan enduro heavy grade'. Bought from the withamgroup.co.uk in 5 litre quantity.
Simply one of the best products ive ever come across. So much so, i set up a FB page called the "lanolin appreciation society". Yepp im nuts!!
- CC Baxter
- Visitor
Chris
- Andy2640
- Visitor
CC Baxter wrote: Thanks Andy, I like the look of this. I think I'll get a can for experimental purposes.
Chris
Good stuff CCB,
Keep me posted on this. Ive converted another chap to lanolin on FB too. He has now joined the lanolin appreciation society and has fell in love with this sticky sheep excrection aswell.
Nice1 CCB, let us know how you get on.
- Thank you received: 70
All it does is, to cover up the rust and in some cases allow it to propagate behind the coating, which can make matters worse by effectively sealing in moisture. Our last Land Rover was "Dinitrol'd" and when l inspected it after a few years, rust was propagating behind the coating and large flakes of rusty steel could be scraped off.
I would use a spray grease or product such as XCP which is clear, and doesn't harden.
l looked under our 2020 Jimny and it does seem well protected as standard, but l will empty a few tins of XCP over the body mountings and inside the chassis rails.
- Roger Fairclough
- Thank you received: 193
Roger
- Thank you received: 468
m.facebook.com/groups/1007337742802763?v...&id=1419657618237438
m.facebook.com/groups/1480549812004311?v...&id=2970432803015997
- Thank you received: 551
Hi Roger,
These are people's pride and joy so it's not nice to point out flaws, but photos do exist of new Jimnys with rust starting. Many have not see the first salted winter road. I've been looking at photos of G4 from launch and have seen the same sign's that I came across when I was looking for my new G3. I was shocked just how poor the rust protection was on the G3 compared to the vehicle manufacturers I was leaving behind.You need to make your own mind up, but if I was to get a new G4 it would be waxed before it turned a wheel.
Some photos from this site for those that don't do FB.
The brown stains are not wax and these are new low milage vehicles. One small area, three rust patches starting.
- Andy2640
- Visitor
lightning wrote: Having owned Land Rovers for years, l am against clagging the underside of the vehicle with black "waxoyl" or similar products
I struggle to see how rust would continue to spread if it was hermetically sealed by an oil or wax. Rust needs oxgyen to progress.
However slapping a "coating" over serious rust probably wouldnt help much. Too far gone.
Ive read so much about corrotion, and many rust proofing companies benefit from blinding you with sciencen in order to make you believe it cant merely be done by the average man, and requires a booking in at there facility. But in saying that some of them seem fairly reasonable considering the time it takes to complete.
If youve got a new jimny, choose a dry warm day and slap a load of lanolin on it. No mess, no oils, no staining. Just a natural product that will seal your chassis in natural sheep oils.
- Thank you received: 1755
- Bill Portland
- Thank you received: 77
I'm becoming tempted to doing it myself, mostly due to the lack of interest by those I've contacted for a quote. How did you raise yours to get underneath Andy?Andy2640 wrote:
- Andy2640
- Visitor
Howdy buddy!
I put my jimmers on 6 ton axle stands, and added wheel ramps and wooden blocks just to be extra safe. I then slid under and spent the day underneth with a documentary running on my mobile. It was actauly really fun, the lanolin is lovely to work with, and is safe for eyes and ingestion.
A fully thorough job can be achieved with enough roon to get underneath.
