BigJimnyMeet 2024
No braking force
- tlacee
- Visitor
28 Jun 2020 03:07 - 28 Jun 2020 03:09 #224115
by tlacee
No braking force was created by tlacee
Hi guys. I have a 2004 Jimny Sa(n)tana with ABS. No issues so far, but it failed Inspection recently due to low braking force on rear axles. I changed already the calipers, drums, liquid, central pump, then proportioning valve.... no change. The car brakes ok, no issues on the road but the force is not higher than 46% on the rear brakes. Clueless what to do next.
Any ideas are welcome
Last edit: 28 Jun 2020 03:09 by tlacee.
- Thank you received: 1759
28 Jun 2020 06:08 - 28 Jun 2020 06:10 #224116
Replied by Lambert on topic No braking force
Welcome to the forum. The 46% is that equal across the axle, at both wheels? I'm trying to remember what I had on my last test and I seem to think it was something like 350kg to 400kg on each front wheel and about 120kg to 150kg on each rear wheel and that was considered good. What I am saying is I'm surprised that 46%rear breaking efficiency is failing a test simply because the breaking system of all cars is designed specifically to put most effort into the front brakes so that stability is maintained. As you brake weight is transferred to the front of the car so having too much braking effort at the back will cause the rear wheels to lock and slide.
What level is your testing centre wanting for a pass?
Last edit: 28 Jun 2020 06:10 by Lambert.
28 Jun 2020 06:19 #224117
Also have you changed the flex pipes there's one on each front and one for the back axle it is possible they have failed internally.
The following user(s) said Thank You: tlacee
- tlacee
- Visitor
28 Jun 2020 14:12 #224140
by tlacee
Replied by tlacee on topic No braking force
Well, Indint know the details regarding the requirements, and I am a brand new Jimny owner.
Anyhow, I found a donor abs modulator, I ll ask the workshop guys to change that too, amd see what happens.
It is weird, because the front axle brakes are perfect, and the rear handbrake is also working great. I ll try also the flexible pipes as recommended below.
If there will be no option, I ll have to take it to a Suzuki dealer service, but that is really expensive here.
Thanks for the tips.
28 Jun 2020 14:34 #224142
Abs shouldn't be affecting the brake effort at the rear wheels if it's getting 46%. Again I am concerned that 46% effort is considered inadequate?
- tlacee
- Visitor
28 Jun 2020 15:46 #224147
by tlacee
Yes, it was inadequate, and it didn t pass the inspection. I ll ask tomorrow for the test sheet at the workshop to be sure regarding the figures. The test result was with 4-5% below the minimum legal requirements.
28 Jun 2020 16:44 #224160
Just looking at the mot manual and it is saying that after 2010 the total is 58% and before that is 50% total efficiency over both axles as in combined total braking effort divided by the total weight of the vehicle multiplied by 100. So is your 46% the total over both axles?
- tlacee
- Visitor
28 Jun 2020 17:02 #224165
by tlacee
Thanks for the info, ill check tomorrow the test result, and let you know what the exact figures are separate on axles.
Could be that the 46 is the total value.
- Roger Fairclough
- Thank you received: 194
28 Jun 2020 17:12 #224166
by Roger Fairclough
Replied by Roger Fairclough on topic No braking force
Where are you based? The reason I ask is that the figure of 46% does not make sense and I am wondering if you mean 4.6%.
Roger
Roger
- tlacee
- Visitor
29 Jun 2020 06:04 #224213
by tlacee
So, I was wrong. The figure was 43% braking force difference between front and rear, maning rear force was 43% lower than front. The admitted would be 30%. Now the mechanics are checking the abs pump and the flexible pipes.
29 Jun 2020 06:19 #224214
That makes so much more sense. I would be checking all the lines to the back of the car for damage like kinks as well as the flex pipe to the back axle. And as you have a spare abs module to try that too. It certainly sounds like a lack of flow somewhere in the system.
- Thank you received: 332
29 Jun 2020 10:25 #224223
Replied by yakuza on topic No braking force
When my Jimny is due for the MOT I allways change the brake pads in the rear before the test.
Had a Suzuki SJ before with more or less the same brake parts and learned that it helped to change the rear pads a month or so before the test to make them wear in a bit so the braking was good and even.
They cost little new 30-40£ -ish and this keeps me out of trouble or has done so far. (Norwegian MOT and prices might differ from UK)
