Roof cargo platform for Jimny.
- Reason2doubt
- Thank you received: 100
I do laugh when I see Jimny's filled to the brim in the back with two adults stuffed in the front - it's like they are using the Jim to move house
Any opportunity to not play Tetris in the back of the small Jimny is a bonus.
- latenigh
- Visitor
If I, on my way to work, see someone who need a tow or what not, then I pull over.
When on camping/fishing trips it is me and my three kids in the Jimny. So there is so not much space left but the roof.
The roads that we travel are narrow and bumpy. The speeds on these roads vary. But mostly walking and jogging speed.
But we get to where we are going.
I have not been troubled when branches gets stuck in my old roof rack. I just bring out my saw.
- latenigh
- Visitor
- Thank you received: 1755
- latenigh
- Visitor
I would rather reinforce, than add two crossbars.
Keep in mind that the boxes are a part of the supporting? (do not know if it's the right word) construction.
The boxes are bolted to the frame with 6 pcs of M6 each.
The frame is built with 25x25x2 steel. And I have reinforced the four legs with pieces of 15x5mm steel.
Reason2doubt wrote: Great to get the kit up on the roof and keep it out the way; any reasons not to are honestly negligible.
Can't say I've seen many Jimny's like that. But doesn't it make sense to use the space you have available? There are a few 4x4s around my way that drive around 365 days a year with a roof tent on the roof. And countless 4x4s with roofracks that never have anything on them, or perhaps a couple of really heavy things like the spare wheel that normally lives on the back door, a high lift jack that isn't compatible with their plastic bumpers and the obligatory row of lights, all pointing the same direction, and all above the drivers eyeline so they don't actually help when driving. I find that psuedo-preparedness pretty funny. The deisre to look like you are going on a big important adventure, when everyone knows they are just going to the shops.
For me the main advantage of putting things inside a car is they are protected by the body of the car. E.g. they don't get wet when it rains, covered in mud, stolen, weathered, they can't fall or get knocked off and you can access them without a ladder. And the other advantage on a narrow, top heavy car like a Jimny is the weight is down low so it still drives relatively normally. I save the roof space for things that don't fit, like kayaks, canoes or long pieces of wood. My recovery kit, winch and worklight all live in the car.
I get that if you have lots of people in the car there isn't much space left for things, but surely a roof-box is the sensible option? They are light, spacious, easy to access and quick to install and remove. Whilst it's clear a lot of time and craftsmanship has gone into it's construction, 50kg+ of hernia inducing metalwork semi-permanently attached to the top of a tall thing that is only supposed to have 30kg on it seems a very OTT, borderline dangerous, solution to a very simple problem. If it was a support vehicle for a continent-crossing adventure then I'd sort of get it.
- latenigh
- Visitor
Wouldn't the world be a doll place if everyone did the most sensible thing?
- latenigh
- Visitor
- latenigh
- Visitor
I wanted to use as little material as possible due to the Jimnys roof load limitations.
And also cut the corners 45 degrees for the led working lights mostly for the looks.
This design is what I came up with.
With the reinforced legs, and maybe I'll add the 45degrees bars to the legs, my guess is this will endure the stress.
I have access to a handheld device with x-ray that we use to inspect our welding of steam and food piping.
I'm thinking that I will stress this design this summer and autumn, and inspect the welding this winter.
