BigJimnyMeet 2024
Re:Tyre Pressure for 215/75/R15 ?
- B3Hulk
- Visitor
13 Feb 2020 06:38 #218423
by B3Hulk
Replied by B3Hulk on topic Tyre Pressure for 215/75/R15 ?
- Thank you received: 1755
13 Feb 2020 06:56 #218424
Replied by Lambert on topic Tyre Pressure for 215/75/R15 ?
Fair enough if they had the vin they should be able to get the axle weights to help work it all out. Just don't be surprised if you find the ride a bit too firm.
- Thank you received: 319
13 Feb 2020 10:15 #218426
by Gadget
Replied by Gadget on topic Tyre Pressure for 215/75/R15 ?
This supports my own experiences with 215/75R15 Yokohamas. Running at stock pressures or lower made them visibly baggy and fuel economy suffered. They look 'right' at 28-30psi and fuel economy is more acceptable.
01 Oct 2022 17:08 - 01 Oct 2022 18:28 #245263
by pim123
Replied by pim123 on topic Tyre Pressure for 215/75/R15 ?
If you lower to 10 PSI won't the tpms go crazy ?
One of my standard tyres went from 180 to 170 and my whole dashboard went orange warning me I was gonna die soon !
Last edit: 01 Oct 2022 18:28 by pim123.
02 Oct 2022 21:40 #245273
by pim123
Replied by pim123 on topic Re:Tyre Pressure for 215/75/R15 ?
If you put larger tyres on the gen4 with higher pressure, won't the tpms system go crazy all the time ?
03 Oct 2022 03:28 #245276
Replied by Lambert on topic Re:Tyre Pressure for 215/75/R15 ?
The tpms is a simple system. As long as it sees over 1.6 bar as an absolute minimum it is happy. It doesn't have an upper limit.
03 Oct 2022 15:23 #245292
by pim123
Finally, I have an answer, thank you very much !!! But if I lower my pressure for sand or rocks, it will go crazy ?
03 Oct 2022 17:00 #245294
Yes it gets very cross. It's another case of one system being used across an entire range of vehicles because it's cheaper than designing a separate system for a specific application that has unique requirements. Also you can't turn it off even with an obd tool, you can just reset it but it will go off again soon immediately. Really helpful when the terrain requires 12psi all day.
04 Oct 2022 19:24 #245306
by pim123
I see on Youtube vids where they use a switch to kill the fuse temporarely, seems to work
06 Oct 2022 13:04 #245319
by saxj
Replied by saxj on topic Re:Tyre Pressure for 215/75/R15 ?
I'm really glad we don't have TPMS on our local Jimny's, it would drive me absolutely insane. I run 1.5 bar (22 psi) on road and 0.5 bar (7 psi) off-road.
- lookonimages
- Thank you received: 64
09 Oct 2022 18:32 #245350
by lookonimages
Replied by lookonimages on topic Re:Re:Tyre Pressure for 215/75/R15 ?
1.6 to 1.7 bar.
anything more and you really have uncomfortable drive.
24 Oct 2022 02:48 #245550
by NelsonB
Replied by NelsonB on topic Tyre Pressure for 215/75/R15 ?
HR version here came from factory with 215x75 R15! However, It also came with the jampanese pressure recomendation (based in the 205x70 R15 (23front 26 rear). Good for gasoline economy, but very hard drive! Also, the original schocks did not last too much (not economic at the end). I changed suspension to OME and use 22 front -24 rear, most of the time. Soft sand drive, have to reduce to even 8 without problems! BF| ATs.
Time to create page: 0.188 seconds
