BigJimnyMeet 2024
Bonnet S
- Thank you received: 1761
22 Jan 2020 17:37 #217550
Whatcha. Has anyone successfully managed to separate the chrome S from its mount on the bonnet badge? I'm wanting to wrap mine in the same yellow as my mirrors. Is it just little tabs or is it a little bit more complicated than that?
- Max Headroom
- Banned
- Thank you received: 217
22 Jan 2020 18:26 - 22 Jan 2020 18:27 #217559
by Max Headroom
Replied by Max Headroom on topic Bonnet S
Yes I've done it!
Depending on which badge you have on yours, the S sits in a small recess of raised plastic, on the plastic grille panel.
I'm about to step out to work (nights ) but I will send some photos of it later - but from memory I think there are some small location pins on the back of the S, and it was glued on - just took a lot of careful prising off.with the tip of an old small electrical screwdriver that had the tip of its blade bent over at 45 degrees to assist in getting it off.
It will need bonding back on and I would suggest scratching the surface up nice and coarsely and using ideally, some polyerethane adhesive such as this one but you might get away with silicone sealant, bond it back on
Last edit: 22 Jan 2020 18:27 by Max Headroom.
- Visitor
22 Jan 2020 20:02 #217562
Replied by Daniel30 on topic Bonnet S
you pimping your badge Lambert??
- Max Headroom
- Banned
22 Jan 2020 22:55 #217567
by Max Headroom
Hi Lambert. I'm (very surprisingly) just back in from work and it's not even 23:00 - thought I wouldnt be back here until 08:00 tomorrow, but going out to the workshop now will wake every man and his dog up so I will get more info tomorrow.
I didn't put mine in hot water when I removed the 'S', I just did it as it was at room temp, but that's not a bad idea and certainly worth trying.
Bear in mind the chrome 'S' is fairly thin and has the potential to break if you overdo it levering it off.
An alternative glue when re-attaching it could be one of those hot-glue guns - but I dont know how well that would stand up to extreme cold and heat temperatures.
The polyurethane adhesive I mentioned earlier is used to bond things together that you don't want to ever come apart - friends of mine with kit-cars swear by it, and I've used it for various jobs on my vintage car where rivets welding, or soldering has not been a practical option.
23 Jan 2020 05:17 #217571
Yeah. Something to do with hating chrome on cars. The S is going to be a test piece for wrapping something intricate. If it is too fiddly then paint is the answer.
Daniel30 wrote: you pimping your badge Lambert??
- Max Headroom
- Banned
23 Jan 2020 10:28 - 23 Jan 2020 10:33 #217584
by Max Headroom
Here you go, Lambert
Here's what it looks like when removed.
The manufacturer's glue was mostly around the edges on mine. so you will need to gently prise it off a little at a time, carefully working around it . Mine was on pretty solidly - but you may find yours is different. Looking at it closely again the glue might have been that sticky foam stuff often used for car badges - Im sure you will know what I mean by that.
Pictures showing reverse side of badge and how thin it is. No lugs on the rear - it's flat. Hope this helps
Last edit: 23 Jan 2020 10:33 by Max Headroom.
- Thank you received: 332
23 Jan 2020 12:03 #217589
I do not like chrome either. I just rubbed the chrome with a 3M pad and brush painted. Tapping it with the tip of the brush left no brush marks. Will do the same to the other badges some day. Or just remove them maybe.Lambert wrote:
23 Jan 2020 15:49 #217602
I would debadge the back door but management are against that. The other alternative is to replicate the lettering in vinyl, that way I get yellow and they still have the badges, kinda.
23 Jan 2020 18:53 - 23 Jan 2020 18:53 #217616
by Keithy
Last edit: 23 Jan 2020 18:53 by Keithy.
Time to create page: 0.200 seconds
