BigJimnyMeet 2024
Rock Lobster or other reduced ratio boxes
- Thank you received: 34
10 Jan 2010 17:52 #1830
by ooky_123
Former owner of Little "Ooky", who has now started a new life in Shetland
Rock Lobster or other reduced ratio boxes was created by ooky_123
Right, a Mate has just stuck a set of 31x10.5x15's on his sports track and it looks HUGE !!!
So much so .. I want a set... but given the 215rx15's are pushing teh standard gearing to the limit, and I really donot have the time to source and build a TX box, what is the easiest option .... Im happy to part with money if it gets me to my goal
Can they be bought ? how easy is it to sourse the bits and getone built / build it yoruself ?
Ive seem Martin's How to guide and I dont have the time or space to attempt anything like that.
A Bolt on ... away you go solution is I guess what im looking for ..
Anyone ?
Anyone ?
10 Jan 2010 19:56 #1831
by Baz2236
Replied by Baz2236 on topic Re:Rock Lobster or other reduced ratio boxes
Rs manafacturing does a full bolt on sj kit or you can get some Redacted gears put into your t box. Thus keeping orginal speedo drive and props etc. And not fitting an old sj box.
Let me know how you get on cos I am looking todo the same very soon.
Baz
Baz
10 Jan 2010 20:09 - 11 Dec 2010 18:16 #1832
Replied by mlines on topic Re:Rock Lobster or other reduced ratio boxes
I was not personally happy with the special Low Ratio Jimny gearset fitted to my Jimny
I believe mine had had a chain replaced (by changing the transfer box) before I got it and I had to do the same shortly after I got it. The chain slipped badly. The Special Low Ratio Jimny gearset people suggest you should fit a new chain at the time of putting the new gears in but at over £300 this makes it a very expensive option.
A Rocklobster is quite cheap and easy to make, you need to get hold of two transfer boxes, one from a 413 and one from a 410. The 410 ones are getting rarer and more expensive. Then for about £100 you can get the gears cut and swapped.
Rebuilding the transfer box is quite easy despite the apparent long list of steps in my guide.
If you then fit a commercial adaptor kit (Off-Road Armory or -Rob Storr) it becomes a pretty much bolt on solution.
Last edit: 11 Dec 2010 18:16 by mlines.
14 Jan 2010 17:25 #1852
by jonplace
Replied by jonplace on topic Re:Rock Lobster or other reduced ratio boxes
i went down the rob storr route and cant fault it. refurbed box with machined gears, not cut / shut. new bearings too
i paid extra to get the full bucket style fitting kit, totally solid bit of kit, could probs jack the car up off the tbox now. i also bought some poly bushes as the standard ones are a nightmare to work with. seriously the best money i've spent on the car.
- s2quattroturbo
14 Jan 2010 22:15 #1853
by s2quattroturbo
Replied by s2quattroturbo on topic Re:Rock Lobster or other reduced ratio boxes
that looks like a serious piece of kit the plate it is mounted on... think you could easy jack the car on it. bet you cant wait to get out there and try it.
15 Jan 2010 07:51 #1856
by ooky_123
Replied by ooky_123 on topic Re:Rock Lobster or other reduced ratio boxes
Wow .... Gimmi gimmi gimmi ......
Can I ask how much ?
I tried to email Rob but the mail bounced.
Im out of teh country at present, but will certainly try and chase him up when I return
15 Jan 2010 17:17 #1862
by Jamie
Replied by Jamie on topic Re:Rock Lobster or other reduced ratio boxes
Don't e-mail Rob he never replies he is a top guy with the
best product's about, But , He is hard to get hold of!!
15 Jan 2010 17:57 #1865
by jonplace
I installed mine back in may, it works really well for the trials as you can slowly creep round the gates. I opted for the the 4:1 ratio which suits the 30†tyres. Any lower than 4.1 ratio will be a problem in reverse when trying to get out of sticky situations.
Rob has a new email address which I will try and spell out without putting it on the forum
Rob DOT storr AT tesco DOT net (hopefully people can understand that) – he does get back to you but using his mobile may be quicker, his mobile is on his website I think.
if people want to know the price of this kit then I don’t mind putting it on here but I better check with martin first - let us know boss
the cradle is solid all the way round except for a small hole in the bottom for the drain plug.
15 Jan 2010 18:05 - 15 Jan 2010 18:06 #1866
I don't mind people posting about other kit, feel free (and if you see the things I do stock cheaper elsewhere please let me know as well!!)
Last edit: 15 Jan 2010 18:06 by mlines.
15 Jan 2010 18:27 #1867
by jonplace
Ok martin well hopefully this information will help other make their decisions.
Back in may this whole kit cost about £600 if I remember correctly. Of course this price may have gone up or down as that was a while ago now so best to check. I also bought some poly bushes as the standard jimny ones are a nuisance.
The lobster box was about 300ish which included a 4:1 ratio, new bearings and seals also. I had to ship down a donor 413 box which I picked up on ebay for about £50.
The fitting kit was also nearly 300 quid which included the HD bucket (pictured) with all adaptors and speedo kit.
I know its quite a lot of money but I’m not really up to the job of making my own so instead I cheated and got a complete bolt on kit. Its not that much more than buying 2 x Tboxs at £50 each then £100ish for someone to cut and shut the gears. Rob did say that theres approx 100 quids worth of new bearings go into his box’s ?? never had it open so I cant confirm this.
The only problem we had was that the SJ transfer box lever wouldn’t line up with the jimny tunnel hole so we had to put some heat on it and bend it to shape. Fortunately I have access to oxy acetylene kit so this was easy enough to modify.
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
15 Jan 2010 19:40 #1871
by funkyjimny
Replied by funkyjimny on topic Re:Rock Lobster or other reduced ratio boxes
Ive had 2 Rob Storr boxes and fitting kits lol, I had a 4:1 fitted to my new Jimny a few years ago and now i have a 6:1 in my current jimny, which is too low for my 205/16's, i might go up to 235/85/16's (which is what were on the donor car when i bought it, but i didnt fancy cutting out the arches on my new shell so much, floorpan and under headlights need cutting out and new steel welding in)It'd go anywhere with 235/85/16's! Get a lobster box and a locker in the rear axle and it'll be fantastic.
Robs kit is worth the wait ~(and sometimes the mither as he's hard to get hold of!)nicely made, fits perfect, engineering is lovely. I have his panhards, steering bars, rear disc kit, t case with t brake and fitting kit and wheel spacers.
Gary
Gary
15 Jan 2010 20:04 #1873
by jonplace
"i love his panhards" ohh err
funny you should mention lockers i'm looking at putting a kam locker in mine this year if funds allow, a mate has a rear locker and it makes a hell of a difference
have you got a locker ? which one and what do you think
Time to create page: 0.193 seconds
