BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Got one!
  • doncarlyon
  • Visitor
  • Visitor
03 Apr 2011 07:15 #14385 by doncarlyon
Got one! was created by doncarlyon
Picked up a Jimny from up near Edinburgh yesterday, will post some pics later...
Couple of little niggles that need sorting, wondering if anyone can help?
4L will select and works ok, but jumps out unless you hold it in place (which isnt ideal).
The guy i bought it off said it was due to the height (3" Rhino Rays and 2" body lift), said it needs a slight bend putting in the selector, anyone know anything about this?
Also, was considering taking the body lift off as i think a 3" lift will be enough anyway for what im gonna be doing. How easy/difficult is it to remove the body lift?
Cheers!
  • vitara_mad
  • Visitor
  • Visitor
03 Apr 2011 08:01 #14392 by vitara_mad
Replied by vitara_mad on topic Re: Got one!
when i fitted the 2" body lift on mine i had to adjust the trans lever slightly so thats easy enough to solve
is it a proper body lift kit fitted or just some box section thats been fitted ???
it will be easy enough to remove depending on how long its been on as some of the body lift kits that are made with alloy blocks & steel sleeve bolts can be hard to get undone if they been on for a long time as they seem to weld themselfs together
  • doncarlyon
  • Visitor
  • Visitor
03 Apr 2011 09:45 #14395 by doncarlyon
Replied by doncarlyon on topic Re: Got one!
its an offroad armoury kit apparently.
  • adamjimny
  • Visitor
  • Visitor
03 Apr 2011 13:29 #14402 by adamjimny
Replied by adamjimny on topic Re: Got one!
easy way to keep body lift is add a further notch back at the back of the transfer lever opening as it allows it a little room and stops it knocking out of 4wd low dead easy to do just half inch extra will be fine
  • doncarlyon
  • Visitor
  • Visitor
03 Apr 2011 15:32 #14424 by doncarlyon
Sorry, not sure what you mean. Can you explain?
  • vitara_mad
  • Visitor
  • Visitor
03 Apr 2011 17:46 #14435 by vitara_mad
doncarlyon wrote: Sorry, not sure what you mean. Can you explain?
adam means if you keep the body lift on you can make the hole in the transmision tunnel that the lever comes through a bit bigger instead of slightly bending the lever
  • doncarlyon
  • Visitor
  • Visitor
03 Apr 2011 17:49 #14436 by doncarlyon
So cut the floor basically?
03 Apr 2011 17:53 #14437 by mlines
Replied by mlines on topic Re: Got one!
Yes - cut the floor, but a neater way is to get the lever bent. You will need access to someone with a gas welder. Heat the lever til it glows cherry red and bend it - simples.
  • bertbuckie
  • Visitor
  • Visitor
03 Apr 2011 17:55 #14438 by bertbuckie
Replied by bertbuckie on topic Re: Got one!
Glad you got one!
Sounds like you got a decent one as well, cant wait for pics :)
  • doncarlyon
  • Visitor
  • Visitor
03 Apr 2011 17:56 #14439 by doncarlyon
Ok spot on... cheers guys!!
  • doncarlyon
  • Visitor
  • Visitor
03 Apr 2011 17:58 #14440 by doncarlyon
bertbuckie wrote: Glad you got one!
Its a bit rough round the edges but its going to be driving through hedges and all sorts so dont matter !
  • adamjimny
  • Visitor
  • Visitor
04 Apr 2011 03:45 #14448 by adamjimny
yeah thats what i meant sorry cant wait for pics!
Time to create page: 0.117 seconds
Powered by Kunena Forum
