Springs
- shootinginger@yahoo.co.uk
- Visitor
- panosd
- Visitor
And you might need a teflon spring spacer at front to correct
the front lean of the car because all 4 springs you are going to fit have the same height.
- Visitor
- vitara_mad
- Visitor
- biggaz
- Visitor
- Visitor
so you wreckon the rover 600 springs will fit a jimny and lift by 3"? why wont they fit the front?
- srcars
- Visitor
shootinginger@yahoo.co.uk wrote: i can see the springs on vitara's being stronger/take more weight, bigger engine, and bigger in size, but as for the rover 600 springs, they may be softer.
Have a search on google or e-bay for vitara front shocks and you will see they are a completely different design to the jimny. The Vitara has a front strut (shock/spring combined) as opposed to the jimnys seperate spring/shock set up.
Rich
biggaz wrote: what about weight difference between vit and jimny? is there much as this may affect the ride!
Other than GV's the vitara should be very similar in weight, remember the Jimny is a bit lardy for a small car at 1000kg+
If you're after a cheap lift and find the rover springs do fit the rear you can buy just 2 spring spacers from dave(bits4vits).
- Visitor
- panosd
- Visitor
The 600 rover springs are not for 3''.
What we use in Greece is a set of 4 rear springs from XL7 for 3'' lift
or most common at the competition setup jimnys 4 rear springs from the calmini kit of 3'' for vitara
which give a real 4'' lift.
The best combination is 4 rear calmini springs from the 3'' vitara kit with Hotbits shocks.
Worth's every one euro that you spend to buy them. This is going to be my next setup.
- vitara_mad
- Visitor
its worth a try
- panosd
- Visitor
But yes if you can find them cheap we dont make a try.
I have 4 rear lada samara springs witch gave me 4'' lift.
