BigJimnyMeet 2024
ProComp spring length, RHD vs LHD?
05 Feb 2011 07:07 - 05 Feb 2011 08:55 #10983
Replied by mlines on topic Re: ProComp spring length, RHD vs LHD?
You are correct. In RHD Jimnys the handed springs are at the rear. Hard to tell from the parts manual what the difference is but its at the rear.
Last edit: 05 Feb 2011 08:55 by mlines.
- srcars
- Visitor
05 Feb 2011 07:47 #10985
by srcars
Replied by srcars on topic Re: ProComp spring length, RHD vs LHD?
If the Jimny had any I would suggest the longer spring may be to counter the twisting from the engine torque
- Ranster
- Visitor
05 Feb 2011 10:16 - 05 Feb 2011 10:24 #10989
by Ranster
Replied by Ranster on topic Re: ProComp spring length, RHD vs LHD?
I found the installation manual and the long spring goes to the Rear - right hand.
I also found this interesting PDF from Old Man Emu (OME) which offer same specs as the king springs
www.rocky-road.com/jimny.pdf
** take a look on the remarks regarding the Jimny REAR springs:
OME966 suits japanese built models (RHD) with a 20mm higher right hand side coil.
OME967 suits european built models (LHD) with equal height coils.
Last edit: 05 Feb 2011 10:24 by Ranster.
- Ranster
- Visitor
05 Feb 2011 11:47 #10994
by Ranster
Another input - those are the part numbers taken from suzuki EPC.
As you can see, both front and both rear springs are identical in a LHD Jimny.
For a RHD Jimny there are different part numbers for the left and right springs in the back.
LHD Jimny:
41111-84A00 - SPRING, FRONT COIL
41311-81A40 - SPRING, REAR COIL RH
41311-81A40 - SPRING, REAR COIL LH
RHD Jimny:
41311-81A50- SPRING, LEFT COIL LH
41311-81A30- SPRING, LEFT COIL LH
btw, my car is a 2006 Jimny SN415VD-4 series.
LHD Jimny:
RHD Jimny:
- Strek
- Visitor
05 Feb 2011 17:18 #11023
by Strek
Replied by Strek on topic Re: ProComp spring length, RHD vs LHD?
Once again, what does "handed" mean?
05 Feb 2011 17:31 #11025
I use the term "handed" to mean they only fit one way. So, for example, track rod ends are "handed". They come in left hand versions and right hand versions and the left only fit the left side and the right only fit the right side.
Gloves are often "handed". The left hand gloves only fit the left hand (due to the thumb position") etc.
Therefore "handed" springs are design to fit on one side of the car, but not the other side.
- darthloachie
- Visitor
05 Feb 2011 17:32 - 05 Feb 2011 17:33 #11026
by darthloachie
means specific size or shape depending on what side to goes on - left hand or right hand hence handed
Replied by darthloachie on topic Re: ProComp spring length, RHD vs LHD?
Strek wrote: Once again, what does "handed" mean?
Last edit: 05 Feb 2011 17:33 by darthloachie.
- Ranster
- Visitor
11 Feb 2011 03:15 #11364
by Ranster
Can anyone using the procomp 3" kit can measure the height from the wheel hub/center to the top of the fender - both front and rear?
Thanks!
Thanks!
- Monkey
- Visitor
11 Feb 2011 11:23 #11377
by Monkey
Replied by Monkey on topic Re: ProComp spring length, RHD vs LHD?
I have tough dog springs in my jimny which are made by "KING SPRINGS", when i fitted my lift the springs lengths were slightly different but not by to much, i fitted the longer coil the the RHS or drivers side and i have equally lift all round, even with a driver. Have also spoken a few 4wd shops and they always fit the longer coil to the drivers side here in AUS.
Time to create page: 0.126 seconds
