BigJimnyMeet 2024
× Are you building a Mud Monster or a Pavement Princess??
  • X8GGY
  • X8GGY's Avatar Topic Author
  • Platinum Member
  • Platinum Member
  • but currently AWOL
19 Apr 2020 17:44 - 19 Apr 2020 17:51 #221280 by X8GGY
Nice long fruitful day in the garage today... my missus had a bit of a shock when my alarm went off at 8'ockock, so that I could be in the garage at 9am, and worked til' 6pm... keen to get it done for when this pandemic finishes, lockdown ends, and we can get back out in the countryside...
I'd been thinking about things in the shop this week, one of my staff was off, so I spent 13 hours most days at the till, looking at progress photos from this build thread on my iPad, it keeps me going on long days of getting pissed off with (old) customers not having a clue about social distancing for their safety and the safety of others, so I was keen to get out in the garage for the day, rock tunes on Spotify, and the kettle not far away... ;)
One of the things I'd thought about... so I remounted the headlight to work things around...
I then spent some considerable time measuring and re-measuring, and cutting up some box section...
How do you make box section curves? ;)
All welded up!...
Lovely! B)
Out comes the angle-o'meter to work out the a-pillar tubes...
To make another order for Tom "tube-bender" on eBay...
Some more CAD (Cardboard Aided Design) Keithy ;)
To make upper mounts for the front lorry wheel arches...
And weld them to the new inner arch to slam panel bent box bits...
Note also the lower mount at sill level on the door post that has also been welded up and finished...
Extreme-CloseUp! (Wayne's World reference!) :lol:
More "CAD"...
And that's how I ended the day, getting there slowly...
But, I was thinking about this in the shop too... I've still got to replicate all this for the other (Alan's) side yet too! :LOL: :(
Ah well, keeps me busy during lockdown! ;)
More soon, hopefully Wednesday...
Off for a Chinese "fakeaway" with the family, and a couple of (more) cold beers! B)
Last edit: 19 Apr 2020 17:51 by X8GGY.
The following user(s) said Thank You: Max Headroom
19 Apr 2020 18:56 #221286 by furo
Replied by furo on topic Dave's la(te)st buggy build...
It looks brilliant Dave!
  • Lambert's Avatar
19 Apr 2020 19:25 #221290 by Lambert
That's another step closer. More good work.
  • X8GGY
  • Platinum Member
  • Platinum Member
22 Apr 2020 16:26 #221386 by X8GGY
A but more today...
Made the other front wheel arch bracket, and two for the back wheel arches, and a loop for the spare wheel strap to attach to...
Like that to match the front ones...
Spare Wheel strap will clip on to this...
I then clamped the two fuel pipes and took the old filler assembly off, reworked it all, and ended up with this B)
I had to adjust the filler and return tubes a bit so they didn't foul on the waffle boards, I'll add some plate to the corner of the outside bottom right waffle mount to stop any rubbing...
  • Lambert's Avatar
23 Apr 2020 03:57 #221403 by Lambert
How much of a little lay down are you expecting to have if you're caging the filler cap? That's my favourite bit so far!
  • X8GGY
  • Platinum Member
  • Platinum Member
23 Apr 2020 04:51 #221406 by X8GGY
:lol: Thanks... yes, the filler cap had to match ? I was just lucky there was already a locking petrol cap under the flap... saved me buying one!
Glad you like it ;)
  • X8GGY
  • Platinum Member
  • Platinum Member
23 Apr 2020 16:04 - 24 Apr 2020 16:54 #221426 by X8GGY
The A-pillar / windscreen protector tubes just arrived... :woohoo:
Excellent / quick service from Tom “tube-bender” on eBay once again... B)
And I’ve got a Screwfix order in for delivery tomorrow... I’ve worn my 44mm holesaw out, stainless countersunk bolts for the wheel arch mounts (bit early yet, but I wanted to countersink the holes to suit), repair (large diameter) washers to go underneath inside the plastic arches, and some paint brushes... thank god they’re delivering during the lockdown! B)
Last edit: 24 Apr 2020 16:54 by X8GGY.
  • X8GGY
  • Platinum Member
  • Platinum Member
26 Apr 2020 15:13 - 26 Apr 2020 16:29 #221526 by X8GGY
Some more good progress today, so much so that I've decided to knock off early and relax for once! ;)
I started this morning, by making the front mounts for the "halo hoop" that goes around the roofline of the buggy...
And I was then about to weld everything together, when I double-checked everything looked right, and decided it needed something else before welding it in place...
Out came the pipe bender (notice the A-pillar tubes on the drive in the background) B)
Two pieces of 20mm OD 4mm wall tube bent and marked up..
(These were destined to become more Jimny steering spacers for bodylifts.. BUT, one discruntled customer on eBay contacted me questioing the manufacturing quality as one was 1mm (!) longer than the other in the pair he received off me (as ZookBOB on eBay), so I spat my dummy and decided not to bother making anymore, so I re-used the seamless tube for.... read-on! ;) My parts are advertised with the tag-line "ZookBOB" with the BOB standing for my proper first name Robert, but more so "Bits On a Budget), so I told the guy to order some "proper" JimnyBits steering spacers and return mine for a full refund! :evil: So, I'd rather be working on the buggy than making inexpensive 'bits' for ungrateful customers! ;) )
Anyway, rant over...
Cut to shape, can you guess what it is it?...
There, the halo hoop all welded in place, with these extra couple of tubes to protect the soft-top when it's thrown back...
So, halo hoop done, and the 'cage' is nearly complete...
I was then going to start the...
... A-pillar tubes, but instead, I brushed up, tidied up, updated the build thread, opened a Stella, and about to throw myself in the shower, and plonk myself on the sofa, and wait for my Roast Lamb Sunday Dinner... B)
Edit : Ahhh, ended up in the Hot Tub for half an hour, soothed my old aching bones ;)
Last edit: 26 Apr 2020 16:29 by X8GGY.
  • X8GGY
  • Platinum Member
  • Platinum Member
29 Apr 2020 15:33 - 29 Apr 2020 16:50 #221645 by X8GGY
Bit more today...
I drilled and slotted the rear arch mounting plates...
Lined everything up, and then welded throygh the slots onto the rear tube loop...
I then measured, cut, and hole-sawed some 50mm box section...
To form the uprights to hold the rear hoop in place...
And then cut, measured, adjusted everything into place ready for a welding session on Sunday..
The rear (SJ/Samurai) light boxes need trimming and capping yet, so that they are...
... just wider than the guards for them.. I'll also make the end capping of the boxes protrude at either end backwards to also protect the light lenses...
The rear arches will be 10" wide * when I've cut some, so 5" either side of the tube centre line, so the rear lights will be the same width as the arches... As wide as the plywood template in the last two photos, sat at the edge of the tyre extremity...
* Luckily, the lorry wheel arches I have are 20" wide, so by cutting them in half I'll end up with a spare set to replace them if they get snatched by trees! ;)
Last edit: 29 Apr 2020 16:50 by X8GGY.
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
29 Apr 2020 18:19 #221655 by Riccy
Thats a tidy looking back end Dave B)
Just needs a sexy exhaust to finish it off :whistle:
these guys are good (but shut atm for coronavirus :-( )... www.304stainlessexhaustparts.com/
Riccy
29 Apr 2020 21:28 #221661 by Scimike
Really impressive work.
Love to watch the build progress.
  • X8GGY
  • Platinum Member
  • Platinum Member
30 Apr 2020 05:46 - 30 Apr 2020 05:46 #221667 by X8GGY
Riccy wrote: Thats a tidy looking back end Dave B)
Riccy
Thanks Riccy! I do like a nice tight neat rear end ;) :lol:
I've got some heat resistant silver exhaust paint? ;) This one's a simple inexpensive build! :ohmy: :woohoo:
Scimike wrote: Really impressive work.
Thanks Scimike !
Last edit: 30 Apr 2020 05:46 by X8GGY.
Time to create page: 0.270 seconds
Powered by Kunena Forum
