Wheel/tyre rotation and TPMS (Gen4)
- Eacg14
Right, Bob?
- Bill Portland
Topic Author
- Thank you received: 77
Eacg14 wrote: Ignition to "ON", press in and hold the button/dial thing on the bottom right of the cluster until the menu pops up. Then you can scroll through the menu and find TPMS reset.
Right, Bob?
Hi thanks, but there's no reset there, just the ability to view the pressures, if the system is working. If it's not working, you just see 4 "--".
You can change from "comfort" to "load" mode, but that's all.
The menu options differ from country to country.
Can I recommend stating the age, model and country in any reply for clarity.
- Bill Portland
Topic Author
GeorgeC wrote:
See Pages 3-69,70,71 in the PDF Manual.Eacg14 wrote: Ignition to "ON", press in and hold the button/dial thing on the bottom right of the cluster until the menu pops up.
Right, Bob?
There is a scanable PDF here: www.facebook.com/groups/2184373498316066/files/
Thanks again George. The manual is a bit misleading in that it states that you have to have a dealer set or reset the system. It is also wrong when it says that the spare doesn't have a sensor. It does - at least mine does, and also those that have had no problems when changing wheels must have one in their spares too.
The good news is that, at the 3rd attempt, I went for another drive and after about a mile the warning disappeared and the system is working fine again, including the spare (which is not the spare anymore). Martin was right, it seems a bit flakey but it will auto reset given enough opportunities. I blame 5g!
Glad its working. I think that the flakiness of the auto is why the UK Dealer manual puts emphasis on the manual reset.
There is a list of reasons in the manual as to why the TPMS system may fail to learn or generally miss read the sensors.
Your joke about 5G is close to the mark. TPMS works on the ISM (Industrial Medical Scientific) frequency of 433Mhz which is bang in the middle of the Military (primary user) and Amateur (secondary user) radio band (UK allocations). Therefore transmissions from these will interfere. The specific ISM frequency is used by all sorts of low power devices such as remote keys for cars, indeed "Remote Keys" is listed as a reason TPMS readings may fail, along with RF shielding (the car is a tin box with the wheels on the outside).
I learnt to not trust it when I lowered the pressures on our Jimny to the proper pressure for our mud tyres. I got the expected alert which would not then clear when the tyre pressures were restored to normal. It took a long journey of over an hour to settle back down. This is probably due to the sensors only running in "fast mode" for the first 10 minutes of a journey (fast is a reading once every 16 seconds) after this it drops to a quarter of this (reading once every 64 seconds - "active mode"). It is easier to miss a reading that occurs only once per minute.
Right, Bob?
Correct - that's precisely what I have and do. And there was me thinking that this technology existed to make life easier for us all. At least Bill now seems to have a solution and hopefully his blood pressure has lowered.
Sometimes I think - What was wrong with just manually checking your tyre pressures every few weeks?
