2wd 4wd
14 Dec 2018 06:44 #198943 by Lambert
Replied by Lambert on topic 2wd 4wd
I too regularly engage front drive on the go though with my manual hubs I need to know in advance that I am likely to need to do so and have them pre engaged usually towing trailers in and out of fields or if snow is forecast.
14 Dec 2018 08:32 #198945 by Max Headroom
Replied by Max Headroom on topic 2wd 4wd
On the electrically selected gear-changer, I have more than once inadvertently selected 4wd (while at speed) when not looking down to move the air recirculation slider, only noticing when the glancing at the instruments and seeing the 4wd light on :unsure:
14 Dec 2018 12:10 #198947 by Busta
Replied by Busta on topic 2wd 4wd
Max Headroom wrote: Someone else will correct me if I'm wrong here, but I'm sure if you are engaging/disengaging 4L that you should be stationary
Yes you should and Suzuki insists that you are stationary. However, with the manual transfer case and a little bit of practice it is possible to do while moving. It's non-syncromesh so you need to rev match, much like changing gear in a vintage car.
14 Dec 2018 17:38 #198956 by Max Headroom
That's "double de-clutching"
On non-synchromesh boxes (found on many pre-war cars) the procedure is:
Clutch pedal 'in' to disco the engine from the g'box, move the gear lever to the neutral position. Then with the clutch pedal 'up', rev the engine in neutral slightly trying to match the rpm for the next gear, clutch 'in' again and select the next gear, clutch up again, and away you go
...takes some practice to do it nicely without crashing the gears :blush:
  • helijohn
14 Dec 2018 20:21 #198969 by helijohn
Replied by helijohn on topic 2wd 4wd
Scimike wrote: Having done it once I will never be doing it again. It was too "mechanically unsympathetic" for me.
+1
