Help me measure gap between roof-rail?
  • OlaGB
10 Dec 2018 06:45 #198827 by OlaGB
Could anyone help me out, and measure the height between roof and rail on theire Jimny?
I`m wondering if theres room for a spesific slim led light under the rail, out to the side for flood lights, bit im away at work for acouple weeks and not able to measure myself..
  • JustCallMeRick
10 Dec 2018 19:19 - 10 Dec 2018 19:23 #198859 by JustCallMeRick
Replied by JustCallMeRick on topic Help me measure gap between roof-rail?
3.2cm measured from the outside the roof rail.
Als slim led bar schould fit.
Edit:https://www.ebay.com/itm/2Pcs-18W-7inch-Cree-Led-Work-Light-Bar-Flood-Suv-Boat-Driving-Lamp-Offroad-4WD/323005766900?epid=2171720750&hash=item4b34a4dcf4:g:s7wAAOSwU91aXhg4
Something like this may fit quite nicely
Last edit: 10 Dec 2018 19:23 by JustCallMeRick.
  • OlaGB
10 Dec 2018 19:38 #198861 by OlaGB
Replied by OlaGB on topic Help me measure gap between roof-rail?
Thanks! Less than i hoped for, but there`s always smaller lights to fit, just like the ones you linked to :)
  • Daniel30
13 Dec 2018 15:02 #198928 by Daniel30
Replied by Daniel30 on topic Help me measure gap between roof-rail?
I would think you would need to allow for any flex if your using the roof rack :)
  • OlaGB
13 Dec 2018 18:04 #198931 by OlaGB
Daniel30 wrote: I would think you would need to allow for any flex if your using the roof rack :)
Yes, needs either some clearance , or rubber between lamps and roof :)
Ordered side flood lights, rear flood lamps, led backing lights and reeaal good LED spot lamps now.. Jimny to be seen from outter space :)
  • Daniel30
13 Dec 2018 20:16 #198933 by Daniel30
Sounds good, get some picks up when your all done ;) ;)
