Wax oil.
- Ruedeleglise
05 Feb 2018 09:11 #189104
by Ruedeleglise
Wax oil. was created by Ruedeleglise
Hi there. After a couple of months with my Jimny I recon I am getting to know her, her good and bad habits! I have been up to the axels in mud and water and been where a Toyota utility and even a Defender got stuck. What I would like an opinion on is the use of wax oil. I used some 40 years ago to inject it and thouroughly smother the underparts , nooks and crannies of my cars. What is recommended and your opinion now?
Attachment not found
- Thank you received: 1876
05 Feb 2018 10:09 #189105
Topping up or starting with an older ca4 I would be using waxoyle or dinitrol or similar. Starting with a new car I would be on with buzzweld,.
- Ruedeleglise
05 Feb 2018 10:55 #189106
by Ruedeleglise
Replied by Ruedeleglise on topic Wax oil.
Thanks. Mine is 3yrs old and was used previously as a shopping trolley.....only 13000 miles. Never heard of Buzzweld....presume Halfords?
05 Feb 2018 12:09 #189108
No , buzzweld is a direct from the supplier thing. They have lots of different types of paintable finishes for different applications. Google them.
The following user(s) said Thank You: Ruedeleglise
06 Feb 2018 20:19 #189145
Waxoyl all the way.
Replied by helijohn on topic Wax oil.
Ruedeleglise wrote: What I would like an opinion on is the use of wax oil. I used some 40 years ago to inject it and thouroughly smother the underparts , nooks and crannies of my cars. What is recommended and your opinion now?
Waxoyl all the way.
06 Feb 2018 21:33 #189148
by kirkynut
Now I'm not a fan of Wayoyl. It can trap moisture under it in pockets, especially if there was already a little rust you didn't know about, albeit a good side brushing ought to be done first.
I'm much more a fan of a proper paint and personally use Hamerite, topping up with fresh coats as required.
I'm not experienced with buzzweld but believe it to be better.
Cavities I believe are best treated in road cars with old engine oil, however, not on a car that will go through Fords or other water and leave a rainbow effect in its wake! Not good for ze fishes!
Time to create page: 0.221 seconds
