Servicing - what needs doing, what is commonly missed?
02 Sep 2017 11:47 #183818
Yes, what was i thinking?! Prop it is
Clutch cable is pretty easy to adjust. theres a small black cover on the driverside of the gearbox which allows access and the adjuster nut outside does the movement.
Replied by Riccy on topic Servicing - what needs doing, what is commonly missed?
jackonlyjack wrote: engine will be M13A unless its a soft top
I think Riccy means grease nipples on the prop shafts
also leave the spark plugs till it miss fires should have iridium plugs in
Jack
The following user(s) said Thank You: fowleronline
- fowleronline
10 Sep 2017 19:13 #183984
by fowleronline
Replied by fowleronline on topic Servicing - what needs doing, what is commonly missed?
From your advice I had a chap look at it when it went in for some welding. He said he was unable to adjust it, but didn't say much except there was no adjustment in it.
I don't know if that means it needs a new cable or there is a clutch issue on it's way. As I said before, there is no slipping, just a very long travel before it bites.
Any thoughts please?
11 Sep 2017 07:35 - 11 Sep 2017 08:21 #183992
Replied by yakuza on topic Servicing - what needs doing, what is commonly missed?
Clutch pedal bracket can turn soft and sometimes even crack.
This is not an easy task, but try to look under the dash board at the bracket where the clutch wire is connected to the pedal assy as you press down the pedal. You will see if the bracket give way from the pressure.
Worn clutch or streched wire may also be the case..
Last edit: 11 Sep 2017 08:21 by yakuza. Reason: add info
- jim
11 Sep 2017 21:24 - 11 Sep 2017 21:32 #184035
by jim
Replied by jim on topic Servicing - what needs doing, what is commonly missed?
There are some helpful how to posts on here which may help you bond with your Jimny
Engine oil:
Gearbox oil:
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=58818
Diff Oil:
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=58878
Fluids Specs and quantities:
www.bigjimny.com/mediawiki/index.php/Forecourt
Engine oil:
Gearbox oil:
Diff Oil:
Last edit: 11 Sep 2017 21:32 by jim.
12 Sep 2017 07:39 #184047
Replied by mlines on topic Servicing - what needs doing, what is commonly missed?
Every now and again check some of the more minor items.
e.g.
Clean out the pipework for the emission system and PCV
Clean the vacuum solenoid filters
e.g.
- fowleronline
13 Sep 2017 09:13 #184075
by fowleronline
Thanks Jim and Martin, very useful stuff.
Although I am unsure as to which language "Clean out the pipework for the emission system and PCV Clean the vacuum solenoid filters" is in, as I have no idea what it means lol.
Time to create page: 0.160 seconds
