- Thank you received: 923
25 Jun 2020 15:49 - 25 Jun 2020 15:52 #223994
A bit like me then?...
My mum has always said I’m “special”...
And my missus says I’m definitely “one of a kind”
I think they both mean it in a nice way though...
:lol:
Reason2doubt wrote: Great updates - very inspiring! Love this build simply because it is so unique.
Last edit: 25 Jun 2020 15:52 by X8GGY.
27 Jun 2020 13:20 #224083
Sad
this morning... as the postman didn’t bring my expected parcel this morning...
But then the Hermes lady turned up, with these...
For my old tree wires to run through / mount to... :woohoo:
Is It Sunday Yet?!
Is It Sunday Yet?!
27 Jun 2020 14:15 - 27 Jun 2020 20:35 #224089
Sneaked our of the shop...
So the big lifting eyes go on the ‘halo hoop’ above the windscreen, next to the A-pillar bars which is what prompted me to get them now, might as well weld the mounts (those big M16 bolts) on at the same time?... Then the smaller clips on the end of the (Rescue helicopter winch) stainless steel rope just fit through the loops and clip to each side of the turnbuckle which ends up above the middle of the windscreen... The other ends of the cables will clip to the top of the front mudguard mounting plates using the ‘smaller’ M12 eye bolts..
There’s always been some question of legality of driving on the road with “tree wires” fitted, so I made these many years ago so that they can clip on and off quickly and easily, and just attach them for the mad lanes
So to fit them you just have to clip the four ends of the cables to the wing tops and turnbuckle and then stand on a tyre and tighten the cables taught with the turnbuckle... Simples!
Last edit: 27 Jun 2020 20:35 by X8GGY.
28 Jun 2020 16:53 - 28 Jun 2020 17:10 #224162
Bit more today... but I woke up in a CBA mood, but after walking the dogs and having a cooked breakfast, I was raring to go...
I started with the tree wires as they were fresh in my mind as the lifting rings had arrived yesterday...
So the cable runs from the top of the front wing mount and up through one of the huge rings on the 'halo hoop' of the 'cage'...
I mounted the ring just next to the A-pillar bar... it's M16 so I cut off the head of the M16 bolt and drilled a hole in the halo hoop and poked the threaded bit of the bolt into the hoop and then popped a washed over the top, then worked out where the thread needed to stop so that the the lifting ring ended up in the right place, and then welded up to the washer to make the shaped mount for the ring...
The idea being that the smaller hook at the top end of the cable (that connects to the turnbuckle in the middle of the halo hoop above the windscreen) JUST fits through this huge ring, so you first clip the cable to the top of the wing, thus -
And then thread the other end through the big loop, and attach it to the turnbuckle, and then when the two are in place, tighten them taught with the turnbuckle...
I then made a mounting bracket for the charcoal canister thingamebob...
And with it welded to the top of the spring mount, I painted it and then bolted the canister in place, and then added a BREATHER silicon hose, that leads up to...
An additional T-piece in the breather system...
Then onto the front mudguard mountings...
Having..
... adjusted the rear mount to the shape of the mudguard...
And trimmed the front to suit... deciding to go...
Level with the bottom edge of the bonnet / top of the bonnet slam, and half way in relation to the headlight...
SO... that, I think, is the driver's side finished!
So, Wednesday, I'll push the buggy out of the garage, tidy the garage, turn the buggy round, and push it back in again...
Ready to start on the passenger side next Sunday...
Having..
Last edit: 28 Jun 2020 17:10 by X8GGY.
28 Jun 2020 17:32 #224169
by Scimike
Replied by Scimike on topic Dave's la(te)st buggy build...
It's been very interesting watching the development of the buggy so far. They say if it looks good, it will fly good - it's going to fly!
The hard development been done, so at least the decisions and waiting for parts is covered for side two, just copy side one. :laugh:
It is looking good.
Mike
It is looking good.
Mike
28 Jun 2020 18:14 - 28 Jun 2020 18:16 #224175
Thanks Mike!
Yes, all the hard work is done, it's just replicating it all on the front two thirds on the other side now :lol:
And then the final yellow paint, electrics, new windscreen, replacement clutch and cable, registration. MoT, insurance... shakedown... hmmm, mid August?! Seems doubtful with it being 6 weeks away...?
It might get it's debut at the BigJimny Meet 2020... with a warm coat and scarf on! :laugh:
We'll see... time will tell...?
Last edit: 28 Jun 2020 18:16 by X8GGY.
