- 1 Introduction
- 2 General issues and solutions
- 3 Operating principle of Jimny's 4WD transmission system
- 4 Operating principle of Jimny's pneumatic hub system
- 5 Fault finding overview
- 6 Checking the 4WD transmission system
- 6.1 Problem 0 - Somewhere else
- 6.2 Problem X - Sporadic issues
- 6.3 Problem 1 – 4WD switch has failed
- 6.4 Problem 2 – 4WD switch wiring has broken
- 6.5 Problem 3 – Electric fuse has burned out
- 6.6 Problem 4 – 4WD controller has failed
- 6.7 Problem 5 - Vacuum pipes blocked
- 6.8 Problem 6 - Vacuum/air leaks from the system
- 6.9 Problem 7 – A solenoid has failed
- 6.10 Problem 8 – Pressure switch failure
- 6.11 Problem 9 - Hub head clogged or worn
- 7 Emergency options in case of a 4WD system failure
- 7.1 Main overview
- 7.2 Situation if the vacuum system fails
- 7.3 Situation if the wiring under the car is broken
- 7.4 Situation if the transfer box fails
- 7.5 Situation if the 4WD controller fails
General theory
- Most vehicles with part-time 4WD transmission (like the Jimny) have (un)lockable free wheeling front wheel hub heads / caps, which can (dis)connect the road wheel hub assembly from/to the transmission (the CV joint).
- The hubs heads / caps sit on the ends of the axle - they visibly stick through the hole in the center of the wheel.
- With them unlocked, the wheels are free to rotate on their own, without turning all the bits and pieces in the (front) axle - that's the "free wheeling" part of the name!
- This saves fuel, saves on mechanical wear of the disconnected components and improves performance when the vehicle is in 2WD (RWD) transmission mode, as it is pointless to turn a lot of gears and metal if they are not required.
- However, in 4WD transmission mode, the hub heads lock the wheels to the drive shafts in order to let the engine turn the wheels.
- Jimnys have pneumatic (vacuum) (un)locking free wheeling front wheel hub heads / caps.
- To clear any misunderstanding - free wheeling wheel hub heads have no relation to differential lockers or with the action of locking a differential.
- They also have no relation to reduction gearing, nor with any form of traction control. And they generally don't bring bad nor good luck!
- On the other hand, if you paint them to look sexy, they might attract some females (depending on the species - wolf, bear, lion, skunk, etc.).
Wheel hub heads / caps are usually just shortened in naming to "hubs", but a "hub" is actually an entire wheel hub assembly - the casing which contains the wheel bearing with its seals, the steering knuckle surround casing, the king pin bearings and (in the case of the Jimny) the pipes and passages which transport the air / vacuum through the wheel hub assembly to/from the free wheeling wheel hub heads.
Pneumatic (un)locking wheel hub heads
Advantages
Pneumatically (un)locking free wheeling hub heads is the most convenient design - it combines the best operational attributes of manual and automatic locking hubs heads, and eliminates the issues of both:
- Unlike manually operated free wheeling hub heads, it is not required that the driver exits the vehicle to fiddle with anything when switching between 2WD<->4WD modes;
- Unlike most automatic free wheeling hub heads, vacuum operated free wheeling hub heads can (dis)engage "in situ" - without requiring that the vehicle/wheel makes at least one full wheel turn during the (dis)engagement process. This attribute makes vital difference if 4WD engagement is about to be performed after the vehicle had already got stuck in 2WD.
Disadvantages
However, pneumatically operated free wheeling wheel hub systems are the most delicate, with the highest risk of failure.
- There are multiple points where an air (vacuum) leak can occur, and it's not just in the conducting pipework.
- In most pneumatic designs (Jimny's included), the air ("vacuum") passes through a significant part of the wheel hub assembly (which consists of the wheel bearing and various shims, bushings, seals, spindles, washers, circlips, gaskets, nuts, bolts, pins, casings, bowels, nerves, bones, skins, veins, arteries, capillaries, nails, hairs .....).
- Even a slight wear out or improper seating of some of those components (example: wheel bearing or wheel bearing seals) can cause an air leak, rendering the pneumatic system impotent.
- The system also consists of some valves and switches in the engine bay (which control when and in which direction the air ("vacuum") goes). They can also be a point of failure.
- Last but not least, there are some computers and electronics, which run the system.
- Another vehicle which uses pneumatically operated (un)lockable free wheeling wheel hub heads is SSangYong Musso, and it is notorious because of the issues with its pneumatic hub system.
- Most Jimnys (especially those which are regularly used in all-terrain duty) will, inevitably, have problems with the vacuum system for the free wheeling front wheel hub heads.
- Diagnosis and repair, depending on the issue, can range from a quick detection and a simple/cheap fix, to a thorough investigation with expensive repairs.
- The purpose of this article is to explain how Jimny's vacuum system works, and to assist you in the diagnosis of its faults.
- Eventually, you may consider changing the vacuum operated free wheeling hub heads to manual or even fixed ones (like in Samurais and other classic 4WD vehicles).
- That procedure is explained in a dedicated wiki article "Manual or fixed front wheel hub heads".
- In order to properly understand the role of the vacuum system for the free wheeling front wheel hubs, you should first properly understand the operating principles of Jimny's entire 4WD transmission system.
- That topic is covered in a dedicated wiki article "4WD transmission system operation".
General overview
- Jimny's pneumatic (vacuum) system for the free wheeling front wheel hubs is a subsystem of vehicle's 4WD transmission system.
- The other (physically unrelated) subsystem is the transfer box with its embedded status sensors + wiring, and with a mechanical selection lever (in the older design) or with a electro-mechanical actuator (in the newer design).
- These two subsystems are then functionally joined/operated together by a dedicated computer called the 4WD controller, so they all together functionally form the 4WD transmission system.
The construction of original vacuum free wheeling hub heads
- The free wheeling hub heads fitted to the Jimny are “sliding collar” designs.
- The collar is pulled onto the drive shaft or pushed off from the drive shaft (depending on the need) by the vacuum from the engine.
- This highly simplified picture shows the theory.
- The sliding collar on the picture in in the locked position, as it is slid on the drive shaft, so the drive shaft and the wheel are in a solid connection.
- When the collar moves to the left, it is out and is not engaged on the drive shaft splines.
- The vacuum makes the collar slide in the desired direction (depending on through which route the vacuum came), but then is NOT required in order to hold the collar in position.
- Once the collar has slid in either direction, it will stay there through the use of magnets and friction.
- The vacuum is used to make it slide both to lock and unlock by changing the route of the vacuum (valves and switches control the route) - removing the vacuum tube from a locked hub assembly will not unlock its hub head.
How the vacuum system works
This guide was written based on a RHD (right hand drive) petrol Jimny configuration.
The situation in LHD petrol Jimnys might differ in the positioning of some elements.
The vacuum system in diesel (DDiS) Jimnys differs significantly in some aspects.
Read the wiki article "Diesel (DDiS) Jimny specifics" for more information.
- Underneath the car, on the side of the transfer box, is a small switch operated by a ball bearing inside the transfer box.
- A 12 volt output from 4WD controller is fed along the blue/black striped wire.
- The 4WD switch shorts this 12 Volts to earth and tells the car that you want to select 4WD, so it needs to operate the hub heads.
Handy "Get You Going" Tip:
- If your diagnosis is that the switch has failed, then you can short the blue/black striped wire to the car chassis/body.
- Pull the connector under the car apart and short the pins together with a bit of wire.
- If the switch is working properly, it will now short out the 12 volts and the 4WD controller now has been told to operate the hub heads.
- Under the bonnet are two solenoids that Suzuki call VSV1 and VSV2.
- The picture shows where the vacuum system is, it’s on the driver’s side at the rear of the engine compartment, under the battery mount (UK cars).
- The vacuum for the system is taken from the intake manifold.
- If first goes through a check valve, whose purpose is to isolate the faults in the vacuum hub system from affecting the engine intake.
- The picture shows the valve and its pipe from the manifold.
- The vacuum is next fed from the check valve down to the solenoid block containing VSV1 and VSV2 valves.
- In the picture, the green arrow shows the check valve (see previous picture), the yellow arrow points to the valve block (with pipes marked 1 and 2 exiting one end) and the red arrow points to the pipe leading to the vacuum tank.
- The vacuum tank is located under the front wing and stores the vacuum, so that the free wheeling hub heads can be operated without the engine running.
So back to how it operates:
- Having got the signal, the 4WD controller sends a signal to VSV2, its the top valve in the valve block with the pipe marked “2” coming out of it (note: yours will not have the handy labels I have added to mine!).
- The second solenoid (VSV2) is the solenoid that locks the wheel hub heads.
- The controller sends a pulse of 12 volts for 5 seconds only, opening the valve for 5 seconds.
- This "sends the vacuum" down the “lock” tubes to the wheel hub heads.
- It is handy to note that the “lock” tube is the one marked “2” in this picture.
- The 4WD controller leaves nothing to chance, and there is another switch in the circuit, the vacuum monitoring switch.
- This is connected in the vacuum pipe work and operates when it detects the correct level of vacuum.
- Therefore, after commanding VSV2 to open, the controller monitors this switch, which is normally shorting the grey lead to earth checking for it to open (ie. no longer short out the grey wire).
- If the vacuum detection switch does not detect enough vacuum, then the controller flashes the 4WD light on the dashboard.
- The vacuum monitoring switch has a small “air filter” on the side (shown with the yellow arrow below).
- This filter can get clogged with dirt and can stop the system from working – it simply pulls off and washes clean!
- Assuming everything is working correctly, the vacuum is transferred down the “lock” tubes and both hub head sliders slip nicely into the lock position.
- After 5 seconds of vacuum application, VSV2 is released, removing the vacuum from the “lock” tubes.
- The vacuum is “released” through a small plastic filter located on the side of the solenoid block (see above).
- Down at the wheel hub assemblies, the "lock" and "unlock" tubes come either along the trailing (radius) arms (early models) or along the front axle (later models).
- The “lock” tube enters the top of the wheel hub assembly, hidden under the brake caliper. The "unlock" tube enters the side of the wheel hub assembly.
- To some extent the unlock process is the reverse process.
- Once the 4WD signal from the transfer box has disappeared, the 4WD controller sends a signal to VSV1.
- It's the lower valve in the valve block with the pipe marked “1” coming out of it.
- The controller sends a pulse of 12 volts for 10 seconds only, opening the valve for 10 seconds.
- This sends the vacuum down the “unlock” tubes to the hub heads.
- It is handy to note that the “unlock” tube is the one marked “1” in the picture.
- That is the operation of the system "in a nutshell".
- In simple terms, a valve bank sends the vacuum down one pipe or the other for a short duration of time, to pull the slider in the free wheeling hub heads in either direction as required.
- Sadly this process does not always work, so the usual issue is that you need to go through a fault finding process.
- The table below shows the typical faults in Jimny's 4WD transmission system.
- Use the numeric references in the table e.g. "Problem 4" to reference the specific checks in the following chapters.
| Status | Problem # | Problem description |
Before progressing through fault finding in the vacuum system, it is worth checking whether the system is really working OK - perhaps the problem is somewhere else!
- Pull the handbrake on, put the gearbox in neutral, start the engine.
- Put the transfer box in 4WD, and immediately listen for a (more or less) loud click from that wheel's hub head.
- Wait for at least 5 seconds (or even 10), and then try to turn that wheel by hand.
- The wheel should be locked - impossible to turn. If the wheel turns, then it has not locked.
- If it has locked, then move the transfer box out of 4WD, listen for a (more or less) loud click from that wheel's hub head.
- If the wheel turns, then it has unlocked properly.
- Repeat this entire procedure for other front wheel.
- The above test gives you a good idea what is and what isn’t working in the system.
- If all this works with both front wheels, your vacuum system is probably working fine.
- Beware that sometimes minor air leaks, mechanical "quirks" or electrical "quirks" might exist in the vacuum system, which exhibit only in certain conditions (load, temperature, humidity, vibrations, angle, etc.).
- This is the worst situation, when a reliable diagnosis is the most difficult to perform.
- That's why pneumatic systems are notorious.
- In this case, (dis)engagement of the front wheel hub heads can work sporadically - sometimes it works fine, sometimes it does not.
- Therefore, the above checking procedure might complete successfully if the "conditions for failure" (temperature, humidity, load, etc.) are not achieved (read: your stars aren't yet aligned).
- If your vacuum system fails only sporadically, then either drive around and wait until it fails in the middle of a trip (and then immediately perform this check while it's still malfunctioning), or just give up and change to manual free wheeling hub heads.
- The other solution is to sequentially perform all the below mentioned checks, starting from the simplest/cheapest one.
- You need to get under the car for this.
- On the back of the transfer box is the 4WD switch.
- It has a blue/black and a black wire going to it, via a plastic plug.
- The plastic plug pulls apart by lifting the small tag with your fingernail.
- Use a piece of wire to short out the connectors on the end of the wire/plug that disappears up into the car.
- If this makes the 4WD system light come on, then the 4WD switch on the transfer is suspect.
- Use a voltmeter or a 12 volt bulb mounted on some wire.
- Measure between the blue/black wire and ground.
- If the voltmeter doesn’t show 12 V, then a wire is broken or the 4WD controller has failed.
- The fuse is located in the fuse box under the driver's side of the dashboard.
- The fuse box changes on different versions of the car, your situation might be specific.
- The controller is hidden right up under the dashboard on the top right hand side.
- You have to pull the fuse wiring to one side and squint up inside the dash.
- Basically, if this is the point of failure, and you have a lever operated 4WD transmission system, you should probably consider fitting manual free wheeling hubs, due to the typical 4WD controller replacement cost.
- On the other hand, if you have a push-button operated 4WD transmission system, you will have to repair or replace the 4WD controller, no matter the cost.
- However, if you have checked the fuses and they are OK, and you have a voltmeter, then it may be worth measuring some voltage around the controller.
- If you can prise the connector (E74) from the controller and have a voltmeter, you should be able to read the following voltages (with the ignition ON).
- Only do this with the connector disconnected!
- Air conditioning?
- 0 volts (earth)
- Vacuum switch – Open circuit or earth depending on Vacuum switch
- Air conditioning??
- Tachometer??
- 12 volts (from fuse)
- See solutions for the next problem.
- There is no short way around these problems, you need to inspect the system closely and thoroughly.
- First take a look at the pipework around the solenoids, it is quite common for the plastic connectors/tee pieces to fracture at the joints.
- Check the entire pipework for split hoses or cracked hoses.
- Perhaps a hose is pulled off of the wheel hub assembly behind the wheels.
- The grease seal on the wheel bearing can wear out, allowing ingress of mud, water, dirt etc (and also consequently an air/vacuum leak), all of which prevent the vacuum being applied to the hub head collar.
- There are other elements in the wheel hub assembly which might cause an air blockage or air leak if they are worn or greased/installed/seated improperly (for example: wheel bearing locking nut), so thorough checking and care when working with all those parts is required.
- The solenoids have power applied when the ignition is ON.
- Pull the grey wire off each solenoid and short the pin on the solenoid to the ground.
- The solenoid should work and you should be able to feel vacuum if you pull of the vacuum tube and put your finger over the pipe connector on the solenoid.
- First of all – check if the little foam filter on the end of the pressure switch is clean.
- The vacuum switch should be “open circuit” when nothing is happening and goes to “short circuit” when the pressure is correct, BUT remember that the system only pulses the vacuum for 10 seconds!
- If you have the system powered up and functioning correctly with all connectors in place, then the “short circuit” will appear as a 0 volt pulse for about 10 seconds otherwise 12 volts will be across the switch.
- It is fairly simple to demount a free wheeling hub head from the wheel hub assembly and check if it is clogged or worn.
- Just make sure that you mark the exact position in which the hub head was mounted and to mount it in the same position later.
- This principle minimizes the chances of improper seating, therefore minimizing the chances of air leaks.
- If the inside of the hub head is filled with grit or dirty grease (or if it has an excessive amount of grease), its operation can be hindered. Clean it and regrease it.
- Do NOT over grease the inside of the free wheeling hub head!
- Excessive amount of grease can hinder the operation of the sliding collar, or even block the passage of air/vacuum.
- If the teeth on the sliding collar or on the main hub head casing are excessively worn, then you might need a replacement hub head.
- They should be obtainable from vehicle junkyards (or from other Jimny owners who switched over to manual hub heads) for a reasonable price.
Main overview
If the 4WD system fails when 4WD traction is most needed, you might still have some options and emergency procedures at your availability.
- The most common cause of a 4WD system failure is the failure of the vacuum system for the front wheel hub heads.
- The next common cause is broken wiring between the 4WD controller and the transfer box, because the wires are relatively exposed under the vehicle.
- The mechanisms in the transfer box can break.
- Тhe least common cause is the failure of the 4WD controlling computer.
Warning about the ABS system
- If you manage to shift the entire transmission into 4WD mode while the 4WD controller still thinks that the vacuum system is inoperable (green 4WD light is blinking on the instrument panel), the 4WD controller will not inform the ABS controller that the vehicle is in 4WD mode (because it thinks that the hub heads have not engaged).
- Also, if you manage to shift the entire transmission in 4WD mode while the 4WD controller is inoperable (dead), the ABS controller will not be aware that the vehicle is in 4WD mode.
- Whatever the case, if the entire transmission system really is in 4WD mode and the ABS controller is not aware of that, this can lead to improper operation of the braking system while the vehicle is in 4WD mode.
- Therefore, drive slowly and cautiously while in 4WD mode like this!
Overview
- The failure of the vacuum system will cause that the vacuum hub heads on the front wheel do not engage, leaving the front wheels disconnected from the rest of the drive train.
- However, there are several emergency options at your disposal, depending on your 4WD transmission system.
Options with lever operated 4WD transmission
Immediate options
- You can still shift the transfer box into 4WD-H and then into 4WD-L by using the lever, regardless if the vacuum system (or the 4WD controller itself) is operating or not.
- In this case, 4WD-L mode will effectively work as 2WD-L ("RWD-L"), but even that's better than nothing!
- Even "2WD-L" mode can be a life saver compared to ordinary 2WD-H mode.
- The only visual nuisance will be having a blinking 4WD light on the instrument panel while the transfer box is in any of 4WD modes.
Further options
- You can also restore traction to the front wheels ("restore 4WD") by performing the vacuum hub head locking intervention as described below.
- After performing that intervention, 4WD traction capability will be effectively completely restored (except the blinking green 4WD light).
Options with button operated 4WD transmission
Overview
- You will have to fool the 4WD controller that the vacuum system is working fine in order to achieve any remedy of the situation.
- By blocking the vacuum system, or by shorting the pair of wires which go into the vacuum monitoring switch, you can fool the 4WD controller into entering 4WD-H transmission mode.
Option 1 - blocking the vacuum system
- Blocking the vacuum system can be achieved by disconnecting the vacuum pipe from the vacuum monitoring switch in the engine bay, and then by blocking that pipe connector on the switch.
- You can even use your finger to temporarily block the pipe connector on the switch, as it only needs to be blocked while the controller is performing the 2WD<->4WD (dis)engagement procedure.
- This way, when the switch starts to suck, the vacuum will be instantly created in it (as the air passage is blocked), and then the switch will inform the 4WD controller that proper vacuum is achieved.
- This fooling procedure with a finger is best done with one person holding the finger on the switch while the other person operates the 2WD / 4WD buttons, but even a single person can do this if he is very quick.
Option 2 - simulating response from the vacuum system
- On the other hand, if the vacuum system has failed in a way that it can't even generate vacuum at the vacuum control switch (some switch failed, vacuum source failed, electrical failures, part of 4WD controller failed, etc.), the blocking solution will not be applicable.
- In this case, you can disconnect the pair of wires from the vacuum monitoring switch, and short-circuit the wires.
- This will effectively tell the 4WD controller that sufficient vacuum is present in the system (as long as the wires are short-circuited).
Results
- If you fool the 4WD controller to enter 4WD(-H) mode, it will engage the front drive line (the rear is always engaged), and even the green 4WD light will be constantly lit as normal
- The front wheels will of course still receive no torque, since there is no vacuum to engage the front wheel hub heads.
- However, once the controller is fooled and enters 4WD(-H) mode, it will then be possible to normally change it further into 4WD-L mode by pressing the 4WD-L button, without the 4WD controller performing any further checks if the vacuum system is working (until the vehicle is restarted).
- In this case, 4WD-L mode will effectively work as 2WD-L ("RWD-L") mode, but even that's better than nothing!
Further options
- After fooling the 4WD controller as described above, you can also restore traction to the front wheels ("restore 4WD") by performing the vacuum hub head locking intervention as described below.
- After performing that intervention, 4WD traction capability will be effectively completely restored.
- Beware that the 4WD controller will check if the vacuum system is working once after each vehicle start-up.
- Therefore, try not to turn off or stall the vehicle until you exit the "danger zone" where 4WD traction is required.
- Otherwise, you will have to fool the 4WD controller about the operation of the vacuum system immediately after each vehicle start-up.
Procedure to manually engage the vacuum hub heads
The procedure
- Mark the current position of each hub head on the wheel hub assembly.
- Demount both vacuum hub heads using an E10 "torx" bolt driver (which you should always carry in the vehicle).
- Using a finger, slide the inner collar in each vacuum hub head forward to manually lock the hub head.
- If you can, try and jam the slider forward by forcing something behind it (a piece of plastic or so?).
- Carefully reinstall each hub head in the same position on the wheel hub assembly as it used to be, ensuring that the slider inside does not move.
Cautions when driving like this
- As soon as you leave the slippery terrain, try to disengage the transfer box back into 2WD.
- If you manage to disengage the transfer box back into 2WD, you are fine - it will not really matter if the hub heads are still locked in reality.
- If you can't disengage the transfer box back into 2WD, then you must immediately demount the hub heads again and manually unlock them (essentially the same procedure as above, except sliding the inner collar back in).
- Otherwise, you risk expensive transmission damage by driving in 4WD mode on non-slippery surfaces (effect called "transmission wind up")!
- You can visually check if the transfer box is in 2WD or in 4WD mode by lying on the ground near the vehicle and observing the front propeller shaft while the vehicle is moving.
- If the front propeller shaft is rotating, then the transfer box is in 4WD mode, and if it is not rotating, then the transfer box is in 2WD mode.
Overview
- With a lever operated 4WD transmission, the only transmission-related wires under the car is a pair of feedback signal wires, going between the 4WD controller in the cabin and the transmission mode detection sensor in the transfer box.
- With a button operated 4WD transmission, there is also a pair of control wires, going between the 4WD controller in the cabin and the electromechanical transmission mode actuator in the transfer box.
Measures common to both transmission systems
- First of all, try to temporarily fix the issue with some insulating tape or other ingenious methods.
- If you don't have the tape (shame on you!) or if the connection won't hold on itself, at least try to hold the wires connected while someone else is shifting the transmission mode in the cabin.
- This will be sufficient to allow the 4WD controller to finish its job with the transfer box, so that it will then proceed to operate the vacuum system.
- If there isn't anybody else with you, try befriending a wolf or a fox to assist you. A bear is too clumsy. A monkey should be the best. Parrots just talk but don't do crap. A weasel will trick you.
- Now, after the shift into 4WD is successful, before you release the wires and the connection is broken again, the other person should disconnect the vacuum pipe from the vacuum monitoring switch, and hold the finger on the pipe connection on that switch.
- Then you release the wire. After approx. 15 seconds, the other person can release the finger and put the vacuum pipe back into its position.
- Reason:
- Depending on which wire is broken, the 4WD controller might interpret the disconnection of the wire as the return of the transfer box into 2WD mode, and will consequently attempt to operate the vacuum system to disengage the front wheel hub heads.
- Removing this vacuum pipe will thwart its action and the entire drive train will remain in 4WD mode.
Additional measures with button operated 4WD transmission
- You might also have to disconnect the wires from the actuator in the transfer box immediately after the shift into 4WD mode is successful.
- Reason:
- To prevent the 4WD controller from automatically using the actuator to shift the transfer box back into 2WD mode after it loses the connection to the transmission mode detection sensor in the transfer box.
- Failure of the transfer box will probably be rather obvious.
- Either the transmission lever (if equipped) will be jammed or very loose, or something will menacingly bang, grind or squeak in the transfer box during the shifting attempt or during vehicle motion.
- When a transfer box fails, you are unfortunately out of options before a proper servicing is done.
- This happens very rarely on its own, but it can easily happen if shifting in/out of low range gearing is performed when the vehicle is not completely stationery - "user error"!
- It can also happen when driving in 4WD modes on non-slippery surfaces (severe transmission wind-up) - "user error" again!
Overview
- If the 4WD controller has failed completely, that can be most easily detected by noticing that the green 4WD light on the instrument panel is staying OFF (not even trying to blink) when attempting to shift into 4WD mode.
- This is not a fool-proof detection method, as it can happen that actually the light itself is faulty.
- The vacuum system will also implicitly become inoperable if the 4WD controller itself has malfunctioned.
- Your situation and options are essentially the same as in the case of a failure in the vacuum system (read above).
- The only additional differences are:
- The green 4WD light on the instrument panel will be inactive as well.
- If the vehicle has ABS, the ABS will not operate properly in 4WD mode (because it will not be informed by the 4WD controller that
- You are out of options - ordinary 2WD-H is your only transmission mode (unless you know how to manually operate the actuator in the transfer box by "feeding" it with required electrical inputs directly from vehicle's battery!).
- Evaluate whether walking or staying put gives you better chances of a rescue. Some honest praying wouldn't hurt either.
- Failure of a 4WD controller is a rare occurrence, but the only proper insurance against it is having a spare identical 4WD controller with you ...
Page last edited on 21/09/2017 by user Bosanek
