King Pin Bearings
For some reason, the Jimny King Pin Bearings don’t last as long as we would like them to and they are the main reported cause of Death Wobble on this forum.
The pre-load on the bearings is set from the factory and if replaced properly with all the correct torque settings etc, in theory the pre-load should be right and there should be no Death Wobble after replacement, if they were the cause or only cause of it.
I say in theory as it appears that the theory can take a bit of a battering on this occasion and Suzuki brought out some shims to add to the King Pin in an effort to increase the pre-load on the bearing. Martin has replicated these shims and sells them in the Big Jimny Shop here
The bearing manufacturer for Suzuki was/still is KOYO. If you buy your King Pin Bearings from the Bigjimny Shop you will at the time of writing get KOYO’s, so you know they are the correct spec. They will also be at probably the best price you can get them here
There is a guide on how to replace your King Pin Bearings on the Big Jimny website
If you have come from SJ ownership, or have worked on an SJ, note that the shims go on the pin it’s self and not around it on the top. On the SJ you add shims to relieve pressure on the bearings, on the Jimny you add them to add pressure to the bearings.
You can check for wear in the King Pin bearings by jacking the car up, putting an axle stand under the axle on the side you are working on and trying to move the wheel with a hand at 12 o’clock and a hand at 6 o’clock. If you feel any play you can help confirm its the Kingpin Bearings by getting an assistant to press the brakes whilst you are doing it, if the play can still be felt then its the Kingpin bearings, if it disappears then look at the wheel bearings.
Transmission oil on your swivels will show they are likely to have failed and have caused the axle tube oil seal to have failed by the excess movement. An oil seal comes with the bearings when bought from the Big Jimny Shop – replace it.
Track Rod Ends / Steering Rod Ends
Worn Track Rod or Steering Rod Ends will have slop in them and cause Death Wobble.
There is a guide on the main Big Jimny website on how to change them [1]
You can buy new ones from the Big Jimny Shop: [2]
Panhard Rod Bushes
These can wear and as they are there to restrict axle movement, any extra movement can translate to Death Wobble.
You can buy replacement nylon bushes from the Big Jimny Shop : [3]
Front Wheel Bearings
My experience with front wheel bearings on Jimny’s is that they are quite long lasting, which is handy as they are not cheap but can be bought cheapest on the Big Jimny Shop: [4]
There is a guide on how to change them on the main Big Jimny Website: [5]
You can buy the tool to remove them from the Big Jimny Shop too: [6]
Radius Arm / Trailing Arm Bushes
Mainly the front arm bushes are a contributor / cause of Death Wobble but the rears could sent movement through the car and worn bushes are no good to man nor beast and may be an MOT failure if bad enough. The most common bush to give problems is the one on the chassis end of the front arms.
There is a guide on how to change them on the main Big Jimny website : [[7]
You can buy the original rubber ones from Suzuki, as per the part numbers in the guide, or from other suppliers. ADL BLUEPRINT do them for much less but in my experience they do not last as long.
Alternatively, slightly more expensive in some cases but easier to fit are nylon ones. The best come from Super Pro and can be bought from a number of places – Off Road Armoury, Bits4Vits, Jimnybits, KAP Suzuki. Nylon ones sometimes do not have slots cut in them that the original Suzuki ones have, these can mean a firmer ride on the road.
Cleanliness
This is something that came up in the summer of 2013 and was brought to our attention by Rockwatt who solved Death Wobble cases by a simple front axle re-build using new components when worn but in all cases cleanliness.
By this we mean making sure there is no rust on the hub behind the brake disc for the disc to sit on so that it and therefore the wheel sits square on the hub.
So get your wire brush out!
This cleanliness extends to the sealant used in rebuilding the hub. Do not use too much on the Kingpins themselves as this creates a layer when prevents the Kingpin from seating correctly. Also ensure that the Kingpin itself is rust free.
Swivel Seal
Often thought of by "Landrover" experts to be a key problem, these are less of an issue on Jimny's. The seal on a Landrover is key to keeping the oil in the joint, but as a Jimnys joint is "dry" they act more as a dust shield. However they also serve as a "damper" for the steering so it may be worth changing them if you are getting desperate.
Wheel Balancing
Seems obvious but you did get them balanced did you?. If you have chunky off-road tyres then balancing beads can help. If you have the 3-spoke "O2" wheels then thse can give issues, try taking these wheels off and rotating them around one stud position.
There are other suppliers of many of these parts – I have mentioned the BigJimny Shop a fair amount above and I support it as Martin runs this forum for us all and it has to be paid for somehow, along with his time in keeping it running.
I have bought from them all and they are all great to deal with.
One other thing you can do to help it is adding a Steering Damper - available from most of the aforementioned suppliers. I think this is treating the symptom and not the cause but if it helps make your Jimny more pleasurable to drive, so be it.
Taken from the original thread at BigJimny Forums
