Tyre selection and usage - best practices
Revision as of 12:16, 27 February 2017 by Bosanek (talk | contribs) (Sub-chapter "Tyre profiles" expanded)
  • One of the most common questions about improving vehicle's all-terrain performance and endurance is "what is the most effective modification to apply to my vehicle?".
  • Well, using proper tyres, and using them properly, is arguably the most effective vehicle "mod" for all-terrain use!
Note Icon.png"Most effective" can generally mean in the context of cost, performance, simplicity or endurance. Using proper tyres properly can be the most effective "mod" in all of those ways!
Overview of the topics covered by this document
  1. Choosing a proper tyre type for the desired usage;
  2. Choosing a tyre size;
  3. List of various tyre models with remarks;
  4. Best practices on tyre usage (wheel rotation, wheel balancing, air pressures, rim and tyre repairs);
  5. Use of tyre chains for snow and mud conditions;
  6. Special situations and combinations;
General remarks
First of all, some basic remarks about using tyres on four wheel drive vehicles. Each remark is explained in detail in various chapters of this article.
Constraints on tyre combinations
  • Inherent restriction of most four wheel drive transmission systems (Jimny's included) is that the vehicle has to use all four tyres of the same profile (size).
  • Furthermore, all four tyres should be the same model and have a very similar tread depth (even small differences between rotational friction and wheel circumference among wheels can damage the transmission in the long term).
  • This limits the combinations when choosing (buying) tyres.
The spare (5th) tyre
  • The stated restrictions also apply to the spare (5th) tyre, which must not be overlooked!
  • The spare wheel and tyre should be actively used in a 5-tyre rotation scheme.
  • Topic of spare tyre utilization has its own dedicated sub-chapter: Spare wheel and tyre usage.
  • People who venture into serious expeditions and overland travels usually use six identical wheels and tyres in a six-tyre rotation scheme.
Tyre air pressures
  • Frequent checking (and adjusting) of tyre air pressures is much more important for all-terrain use than for ordinary on-road use.
  • Reason: tyre pressures significantly affect all-terrain traction as well as the risk of tyre damage (tyres get hotter with low pressures, for example).
  • The topic of tyre air pressures has its own dedicated sub-chapter: Tyre air pressures.
Wheel (dis)balancing
  • Wheel (dis)balancing is a much more prominent issue for all-terrain use, especially for Jimnys as they are notorious for developing a "death wobble" issue.
  • It is a genetic trait derived from their short wheelbase and solid (rigid) front axle suspension design.
  • See the sub-chapter "Wheel balancing" for more details.
Tyre profiles
  • For all-terrain use, higher profile tyres are always preferred against lower profile tyres.
  • Reasons: higher profile tyres cushion the ride better on all-terrain both for the vehicle and for the passengers, they decrease the chance of rim damage, and they allow better air pressure management.
  • The only disadvantage of "tall" tyres is worse performance when the vehicle corners fast in a bend, but it is insensible anyway to do so in a high, narrow, wobbly, jumpy, twitchy vehicle.
  • Therefore, putting oversized rims with thin tyres on a 4WD vehicle is like putting ballet shoes on a village farmer.
  • A "higher profile" means a "taller" tyre (taller tyre sidewall).
  • The second number in tyre's sizing specification determines its "tallness" as a percentage of its width.
  • An example: for a 205 / 70 / R15 tyre, the second number says that its sidewall height is 205 mm * 0,7 = 143,5 mm.
  • Sometimes a narrower tyre with a higher second number is actually taller than a wider tyre with a lower second number!
  • An example: 195 / 80 / R15 is taller than 205 / 70 / R15 (156 mm sidewall length vs 143,5 mm sidewall length).
Tyre designs for passenger and light truck vehicles can be (among other ways) designed and built for regular "on road" use (the vast majority of tyre models) or (to an certain extent) for all-terrain use.
The difference between those two design approaches is not just in the tread pattern (traction capability). Another equally important aspect is tyre's robustness (resistance to various types of trauma, which regularly occurs off the asphalt), which is generally given dedicated design attention for all-terrain tyres (based on tyre's exploitation expectancy). For ordinary road tyres, robustness is barely considered on itself. Also, tyre's adaptability to different weather conditions is also sometimes given more design thought when designing all-terrain tyres.
There is no official standard to differentiate various kinds of all-terrain tyre designs.
There are three "industry categories" of all terrain tyre designs, based on loose practical usage classifications (from "worse" to "best"):
  • 1. HT - "Highway Terrain"
  • 2. AT - "All Terrain"
  • 3. MT - "Mud Terrain"
Tyre manufacturers usually use this classification to position their all-terrain tyre models in their marketing catalogue.
  • HT tyres generally have the best on-road performance and worst off-road performance of all three categories.
  • MT tyres generally have the opposite performance characteristics.
  • AT tyres are generally in the middle - being good but not great for both.
  • Since these are loose classifications, there are "weaker" and "stronger" tyre models in each category, so each tyre model should be precisely evaluated on its own.
  • For example, Dunlop Grandtrek AT20 could be classified either as a "mild AT tyre", or as an "extreme HT tyre" :).
  • Another example is Uniroyal Laredo HD/T, which could be classified either as a "mild MT tyre" or as an "extreme AT tyre".
A special case are retreaded (remoulded, "protect") tyres. Read more about them in the subchapter below.
HT tyre class
Main traits:
  • Highway terrain tyres are generally meant to be used predominantly on road, with only slight & light off road excursions (possibly rougher gravel, some grasslands, etc.).
  • Their overall tread design and depth is generally quite similar to ordinary road tyres.
  • That means that HT tyres generally have equally proficient on-road performance and endurance even for sharp or very fast driving (and similar fuel economy), but almost equally bad all-terrain performance as ordinary road tyres.
  • However, having the "terrain" part in their name, HT tyres should be slightly more robust than ordinary road tyres.
Conclusions:
  • For (almost) always on-road driven all terrain vehicles, HT tyres can be an optimal choice if the vehicles are driven sharply or at high speeds.
  • HT-class tyres are always recommended over ordinary on-road tyres for two reasons - they should be more robust and they at least formally "suit" the all-terrain image of the host vehicle.
  • However, AT tyres are definitely a better choice if proper all terrain driving is even occasionally performed, and/or if the vehicle is not driven fast or sharply.
AT tyre class
Main traits:
  • All terrain tyres are generally meant to be used in mixed on-road and all terrain conditions (anywhere between 30% and 70% of time for either).
  • They usually have significantly rougher (and a bit deeper) tread design compared to HT and ordinary road tyres.
  • They are a performance compromise which is usually hard to achieve.
  • They are generally good on-road except for sharp or very fast driving, and generally good off-road except for boggy and/or harsh conditions (deep mud, deep snow, sharp rocks, river crossings ...).
  • They are usually significantly more robust than ordinary road tyres.
  • They should slightly impact fuel economy.
  • They can be a challenge to balance properly.
  • Many AT tyres are "all season", which further adds to their "all terrain" value (for example, mountaineers can encounter ice and snow even in June and as early as September).
Conclusions:
  • For all-terrain vehicles which are used for everything - commuting, intercity travel, and various all terrain conditions, AT tyres are the solution.
  • AT-class tyres should not present a jeopardy on the road, and they should be a trusted companion off the road, in the sense of traction and in the sense of reliability.
MT tyre class
Main traits:
  • Mud terrain tyres (also called "Maximum Traction") are generally meant to be used predominantly off road, with only slight easy-going on-road excursions.
  • They usually have very deep and striking ("tractor looking") tread and sidewall appearance, and very high robustness capability through various reinforcements.
  • They excel in boggy and/or harsh conditions (deep mud, deep snow, sharp rocks, tree roots, river crossings, etc.) and offer the best protection against punctures, cuts and chipping.
  • However, they are generally noisy on the road, wear faster and present a real jeopardy if not driven slowly and carefully on a wet road and especially on packed snow or ice.
  • Also, they usually significantly affect fuel economy. Due to their coarse construction, they can be very hard or impossible to balance properly.
Conclusions:
  • For all-terrain vehicles which rarely touch the asphalt and are used on tough terrain, MT tyres should be the weapon of choice.
  • However, MT-class tyres can be a jeopardy on regular road surfaces and they wear out faster and louder on road.
  • Also, if not balanced entirely, MT-class tyres will cause issues on road.
Retreaded (remoulded, "protect") tyres
Main traits:
  • A retreaded tyre is a recycled tyre - it is a previously used and worn out tyre, which had its worn tread surface grinded off, and a new tread (which can have completely different pattern from the old one) glued on.
  • The material of the new tread is specific to the retreading "factory".
  • Therefore, retreaded tyres are essentially "tyre zombies" - they are old, worn tyre carcasses which have been restitched and brought back to life like Frankenstein.
Notes on tread patterns:
  • Retreaded tyres are produced in all kinds of editions and flavors, with their treads typically mimicking a well known brand name tread pattern.
  • They can mimic any tread pattern, either of slick and smooth road tyres, summer or winter tread designs, as well as heavy-duty AT, MT or even more extreme agricultural and industrial tread patterns.
  • They can also be made with a custom tread design of any appearance that you can imagine.
Advantages of retreaded tyres:
  • They are quite cheap (usually cheaper than any brand name tyre).
  • They are ecological (recycled material).
  • There is a wide and colorful choice of tread patterns, especially the extreme traction ones.
But there is a cost to pay. Read on.
Disadvantages of retreaded tyres:
  • Bear in mind - if a tread appears the same like from a brand name tyre model, it does not mean that the materials and compositions of the tread are the same (affecting grip, wear rate, etc.).
  • Also, you hardly ever know which actual tyres were used for resurrection - for all-terrain duty, the strength and robustness of tyre's sidewalls are equally important as the tread pattern.
  • There are also horror stories of retreaded tyres failing catastrophically during high speed driving - the tread layer actually glues off from the tyre carcass. The consequences don't look pretty from any angle of view.
  • In some countries, an aggressive tread remoulded tyre could render an environmental fine in some back-country roads.
Beware that Jimnys (as most vehicles with solid front axles) are highly susceptible to developing a "death wobble" issue produced by disbalance or play in their front suspension.
Improper wheel balance is highly likely to trigger it. Retreaded tyres (even those with ordinary on-road treads) are notorious for being hard or impossible to balance.
Here is a document (made by forum user Bosanek) which summarises all arguments FOR and AGAINST using retreaded tyres.
Choosing tyre size
Reasons and benefits
Why would you want to change your tyre size?
  • Well, for all terrain vehicles, the usual strive is to increase ground clearance.
  • Increasing wheel diameter by increasing tyre profile (the second number in tyre size marking) is the most effective way to achieve this.
  • It lifts the entire vehicle (including the axles!), and is dead simple to do for mild increases.
  • There are additional advantages of increasing the tyre profile ("tyre height") - as mentioned in the "General remarks" chapter.
Note Icon.pngWhen a wheel diameter is changed by a certain amount, the vehicle's (and the axles') ground clearance will change by only half as much (by the amount of wheel's radius change).
Basic school geometry explains why.
Issues and risks
However, increasing the wheel circumference/radius incurs the following technical issues:
  1. The vehicle will accelerate harder / slower and will move faster downhill on engine braking (in any gear);
  2. Transmission will have a heavier duty to perform, leading to premature wear in the long term;
  3. Fuel economy can be slightly decreased (because of harder acceleration);
  4. Speedometer and tachometer measurement will change as much as the circumference has changed;
  5. Larger tyres might not fit - they might rub on the bodywork when the front wheels are turning left/right or when the suspension is compressed on uneven terrain;
  6. The larger spare tyre might not fit in its spare position (contact with some vehicle body parts) and/or in its case/cover;
  7. Using snow/mud chains can be risky or impossible, because of (much) less available clearance between the wheels and the surrounding bodywork and mechanical components. However, 4WD vehicles might need snow/mud chains only on steep icy terrain, or for plowing very deep snow. A 4WD vehichle with AT tyres also could benefit of chains in deep soft muddy terrain.
The extent / severity of these issues highly depends on how much the wheel radius has been increased. They should be negligible to slight at most, if you stay roughly within +-3% of the factory size.
Using too wide tyres also induces some of these issues and risks.
Some of these technical issues can be (and usually have to be) remedied in case of significant tyre size increases:
  1. Impact on vehicle's acceleration and engine braking can be remedied by altering the transmission gears ("regearing").
  2. Regearing the transmission will also remedy the load on some parts of the transmission, but some parts, like the wheel bearings for example, will remain under heavier duty;
  3. Tyres can be made to fit properly by two methods - firstly by lifting the vehicle's body or suspension and/or secondly (usually irreversibly) altering the bodywork (trimming the wheel arches, inner arch linings, etc.), the extent of which highly depends on tyre size;
  4. In Jimny's case, the larger spare tyre can be made to fit to the tailgate by installing a spacer on the tyre holder, but the spare tyre vinyl cover or hard spare tyre case has to be custom-made (if badly needed);
  5. Very wide tyres significantly increase the drag force when pulling a bogged vehicle from deep mud.
Some of the mentioned remedies can be quite expensive to apply, and might also imply further modifications. For example, higher suspension lifts require modified radius arm bushes, brake hoses, propeller shafts, adding wheel spacers, buying a new loan at the bank ....
Warning Icon.pngUsing a non-factory tyre size might be illegal or require some vehicle recertification, depending on country or region.
Jimny factory tyre size and approved sizes
  • The factory tyre size on all Jimnys is 205 / 70 / R15.
  • Exceptions are some JDMs (Japanese domestic models) (possibly 175 / 80 / 15 ?) and some Brazilian models (215 / 75 R15).
  • According to some South African and Australian forums (example: this forum topic), their local Suzuki dealers' official policy is to allow +-3% variation in wheel diameter.
  • Therefore, if your Jimny is under warranty (or you want to be mechanically moral), +-3% is your expansion border.
Note Icon.pngIf you want to be certain about this matter, then check with your local Suzuki dealer!
Compatible & interesting tyre sizes for Jimny rims
Quick and simple decision
The three most popular, non-extreme size upgrades are to:
  1. 205 / 75 / R15 - (ground clearance and tyre's sidewall height increase by cca. 10 mm)
  2. 195 / 80 / R15 - (ground clearance and tyre's sidewall height increase by cca. 13 mm)
  3. 215 / 75 / R15 - (ground clearance and tyre's sidewall height increase by cca. 18 mm)
  • However, even these non-extreme sizes may impose certain risks of collisions between tyres and the vehicle body in some vehicle configurations.
  • That mostly depends if the vehicle has 2nd gen. front bumper or not, if it has front mudflaps or not, if wheel spacers are used, etc.
  • The risk is generally the lowest with the first size in the list, and the highest with the third size in the list.
  • Any tyre size upgrade will also introduce certain deviations in vehicle's driving characteristics (road handling, acceleration, top speed, engine braking, transmission's stress).
  • However, for these three non-extreme size upgrades, those deviations range from "negligible" to "small".
  • The first size in the list is the least deviant, as it provides the smallest diameter change, while also keeping the same tyre width.
  • Bear in mind that while the first size might be allowed by Suzuki (depending on company's regional policy), the second and third sizes are definitely not allowed by Suzuki(regional exceptions apply). * Also bear in mind that ANY tyre sizes apart from those which are strictly specified in vehicle's handbook are prohibited in certain countries!
Warning Icon.pngMT class tyres, and especially "remoulded" (retreaded) tyres, typically deviate significantly from their theoretical sizes (they tend to be quite larger)!
Regarding "tyre vs. vehicle body" collision risks
Sizes 205 / 75 / R15 and 195 / 80 / R15 generally have no risks of collisions with the vehicle's body, with two exceptions:
  • If you have a 2nd gen. front bumper (see below), you might have to straighten it if it is sagged, or trim it just slightly (invisibly) on the bottom (simple job with a grinding tool).
  • If you have front mud flaps, you might have to trim a plastic spacer behind them by approx 10-15 mm (which is easy to dismount and mount).
Size 215 / 75 / R15 could be more problematic:
  • It may require some trimming of the bottom of the front bumper, especially if it is a 2nd gen. bumper.
  • Front mudflaps will probably need to be removed.
  • The spare tyre might contact with the rear bumper.
  • Wheel arch trimming is generally not needed, except if wheel spacers are used without a lift.
  • Brazilian "4sport" and "4work" Jimny editions (which came with "215 / 75 / R15" tyres from the factory), also came with an approximate 50 mm body lift from the factory (to remedy the collision risks).
  • The Brazilian "4sport" edition also had a minimalist front bumper, which increased the clearance in front of front tyres (collision risk when steering) and provided higher approach angle.
This was a quick and simple guide to the issue of tyre sizes.
Note Icon.pngIf you have or expect collision issues between your existing or planned tyres and the vehicle, you can remedy them by Lifting the vehicle and/or by Trimming the wheel arches and/or by trimming the front bumper.
Note Icon.pngIf you use a pendant-style towbar-mounted bicycle carrier, a wider spare tyre might collide with the bicycle carrier. This depends on how long the tow ball + tow neck section is.
Read "Towbar" and "Bicycle carriers" wiki articles for more information.
Thorough consideration
  • On the other hand, if you want to dig neck deep into the issue of tyre sizes, study this table on Jimny-compatible tyre sizes, which was made by forum user Bosanek.
  • That table shows all compatible & interesting tyre sizes which fit on Jimny's stock steel and alloy rims.
  • The table also contains many compiled remarks of risks and issues for each non-stock tyre size.
  • Those issues are rarely taken into consideration until it is too late!
Note Icon.pngThe availability of different tyre models in desired tyre size will vary significantly.
Not all tyres are manufactured in every listed tyre size for every market or all the time.
  • As it is evident from the table, even if you choose to stay within Suzuki's alleged 3% allowed wheel diameter increase, there are several tyre profiles which can be used to achieve the goal of higher ground clearance.
  • It is preferred to achieve the goal by increasing sidewall height (second number in tyre profile sizing code) instead of altering tyre width (first number in tyre profile sizing code).
  • Maximum "gain" is achieved if both are increased at the same time.
Tyre models in Jimny-compatible sizes
  • There is a wide variety of HT, AT and MT class tyre models which are available in Jimny-compatible sizes.
  • It would be a pity to use an ordinary limousine road tyre instead!
  • This table (made by forum user Bosanek) contains the list of all brand-name HT, AT and MT tyres which he has found on the worldwide market.
  • In addition to the list of tyre models, that table also contains the availability of each tyre model in most popular Jimny-compatible sizes!
  • A lot of time has been spent populating that table, and adding custom remarks there.
  • The table is still incomplete in some details, but will be updated from time to time.
  • The sizing availability is the most incomplete, as it takes a lot of investigation to fill the required data for each tyre model.
Note Icon.pngNot all of those tyre models in the list are available in sizes which are compatible for Jimny. Sizing availability might depend on the market, and can change for better or worse at any time.
  • Therefore, once you settle on your desired tyre size, now you can browse through tyre models and choose the one which is available in that size and suits your criteria the best.
User experiences with certain tyre models
Here are the AT tyre models with which Jimny owners have had great or good experiences with:
  • Goodyear Wrangler AT/SA+
  • General Grabber AT (not AT2!)
  • Continental ContiCrossContact AT
  • BF Goodrich AT/KO
All three of those models have proven themselves as being very good on-road in any time of year, while also proving to be rather versatile off road.
Also, General has recently (09/2016) released model AT3, which looks very interesting indeed. Avoid the model AT2, it is very old and deprecated one! Grabber AT2 is actually older than Grabber AT.
If you insist on heavy-duty off-road performance but still want to retain some on-road credibility, there are three MT class tyre models with which Jimny owners have been relatively satisfied with:
  • Bfgoodrich Mud-Terrain T/A KM2
  • Hankook Dynapro MT (RT03)
  • Kumho Road Venture KL71
  • Maxxis Trepador M8060 (Martin Lines comment: I have found these particularly good on a standard Jimny)
There are other good AT and MT tyre brands and models of course.
  • All proper all terrain vehicles, like Jimny, come with a full size matching spare wheel, which is the same as the other four wheels.
  • That is for a reason.
  • That spare wheel and tyre are not meant to be just carried around and sit idle all the time.
  • For all terrain vehicles, spare wheel is not a fashion accessory nor a "dead cargo" - it is an important operational element of the vehicle, as well as an important safety device.
  • Therefore, the spare wheel and tyre must not be overlooked. It should be actively used.
  • Otherwise, there are multiple risks of staying stranded in the event of the simplest tyre puncture, or even damaging vehicle's transmission in the event that the spare wheel does indeed have to be used!
  • If you use only four same tyres in a typical 4-tyre rotation scheme, you might easily end up with only three half-worn same tyres - useless for a 4WD vehicle.
  • For example, a sidewall puncture is generally impossible to repair properly. You will have to discard the remaining three tyres and buy all four/five new tyres - what a waste.
However, there are some rules and restrictions when actively using five same tyres - read more in the following subchapters.
Using five identical tyres
Note Icon.pngBuy and use five same (identical) tyres! The spare tyre should not sit idle all the time! That is even written in Jimny's owner manual.
  • The spare wheel and tyre should be actively and periodically rotated together with the other four wheels and tyres, and all should be the same.
  • In other words, the 5th wheel and tyre should play an equal role and importance as the other four wheels and tyres.
  • In case of an all-terrain vehicle like the Jimny, that gives you so much benefits, and only one downside - you pay 25% more at once when buying the tyre set.
Here is a document (made by forum user Bosanek) which shows the rotation scheme, and also lists "FOR" and "AGAINST" reasons to actively use all five identical tyres in a 5-tyre rotation scheme.
  • It is a good practice to rotate the tyres with every engine oil change.
  • If you recently bought a set of four new identical tyres (they have not got worn more than 1-2 mm at most), you still have time to buy the fifth one (you don't need it yet, until the first rotation).
Note Icon.pngThe five-tyre rotation scheme is especially suited to practice when using all-season tyres. Many AT-class tyres are all-season.
Warning Icon.pngIf you have a hard or soft spare wheel cover, you won't be able to use it with a spare tyre which is larger than the stock size.
Note Icon.pngFive-tyre rotation scheme is not practical with tyres which have directional (uni-directional, asymmetric) treads, because each such tyre must be used on only one side of the vehicle for which it was made for. Unidirectional tyres typically have a "Rotation" with arrow mark on their sidewalls, indicating proper orientation. Therefore, when using five tyres, always use non-directional (bi-directional, symmetrical) tyres. Luckily, most HT, AT and MT tyre models have symmetrical treads, but there are exceptions. Beware of this!
Using a non-matching spare tyre
Note Icon.pngUsing (periodically rotating) a matching spare tyre together with the other four tyres is strongly recommended, as per the above subchapter "Using five identical tyres".
However, if, for whatever reason, a non-matching spare tyre has to be used on a 4WD vehicle, special caution has to be applied in order to avoid expensive transmission damage!
This subchapter is a guide what to do in this unfortunate event.
First of all, a non-matching tyre in this context means any of the following:
  • Different tyre size (width or height) than the other four tyres;
  • Different tyre model than the other four tyres;
  • Tyre's tread depth more than 1 mm or 2 mm different than the tread depth of the other four tyres;
The cause of the issue with using a non-matching spare tyre:
  • Any 4WD transmission with a non-existing center differential (or when a center differential is locked) expects the same rotational speed and rotational friction from all four wheels.
  • If that is not the case, the gears and shafts of the transmission literally tension and wind up because of the discrepancies caused by a non-matching wheel.
  • If the tension and wind up become sufficiently high, something in the transmission will break.
  • With a non-matching spare wheel in the game, the breaking point could be just a few wheel turns away!
Installation position
  • With part-time 4WD vehicles like the Jimny, the non-matching spare wheel should always be used on the front axle.
  • The reason is that the front wheels are disconnected from the entire transmission when the vehicle is in 2WD and 2WD-L mode, and therefore using a smaller wheel does not impact the transmission then.
So, if one of your front tyres get punctured, just replace that wheel with your non-matching spare wheel and tyre.
However, if one of your rear tyres gets punctured, the procedure would be:
  1. Remove the punctured rear wheel;
  2. Remove one good front wheel;
  3. Install that front wheel in the place of the punctured rear wheel;
  4. Install the spare non-matching wheel in the place of the removed front wheel.
That's a lot of work if it's hot, cold, wet, dusty, raining, windy or night time! But it is the only proper way.
  • Now, when the non-matching spare tyre is on your front axle, as long as you don't engage 4WD, you should be fine.
  • So, do your best to get to the nearest tyre repair workshop strictly in 2WD mode.
  • If you have manually operating front wheel hubs, make sure that they are disengaged all the time.
Using 4WD mode with a non-matching spare tyre
If you get a puncture in the middle of offroading where you need 4WD to get to civilization, you are in trouble.
  • After installing the spare non-matching wheel on the front axle per the above instructions, constrain the use of 4WD only when it is absolutely necessary.
  • Disengage 4WD as soon as it is not strictly necessary, and engage it later when necessary again, and so on.
  • If you have manually operating front wheel hubs, you have to engage and disengage them every time in sync with engaging and disengaging 4WD.
  • Alternatively, using 2WD-L mode would be safe in regards of the issue of non-matching spare tyre, and it might provide enough aid to get you trough difficult sections instead of using 4WD.
  • However, Jimnys have to be modified first in order to enable 2WD-L transmission mode.
  • See the chapter 2WD-L transmission mode for details.
  • While 4WD is used, the size or friction discrepancy on one wheel will cause constant transmission wind up as long as the vehicle is moving in 4WD.
  • However, as long as 4WD is used on rather slippery ground (snow, mud, very loose gravel), the wind up should be able to constantly relieve itself, without harmful consequences.
  • In other words, one wheel will have to continously "underslip" in order to compensate for the discrepancy.
  • Only very slippery ground can enable that.
  • The most difficult situation would be with rather rocky or bumpy dry road, where you usually need to use 4WD-L 1st gear to pass slowly.
  • Because the road is dry and/or rather solid, there is not enough chance for the transmission to relieve itself of the continuous discrepancy (for a wheel to continuously underslip).
  • Therefore, transmission damage in these conditions is quite likely!
  • Therefore, if you have to use a non-matching spare tyre on a dry rocky or bumpy road, the best option is 2WD-L 1st gear.
  • However, if your Jimny is not modified to have 2WD-L mode, it might be better to use 2WD 1st gear instead of 4WD-L 1st gear.
  • That means you have to go through faster, or drive "improperly" by riding the clutch and/or the brakes.
  • It is the driver's decision whether to risk the damage to the suspension done by going faster through rocks and bumps, or to the clutch if riding it, or on the other hand, to risk damage to the transmission in 4WD-L mode.
Tyre air pressures
Note Icon.pngChanging your tyre pressures to suit the (off)road conditions is the most effective vehicle mod ever!
  • Learn and use the skills of tyre pressure management.
  • The benefit is not just for improved traction, but also for improved ride comfort and reduced vehicle stress!
  • In general terms, reducing tyre pressure by 20-30% from stock on-road pressure is the operating norm for hard (rough) gravel and general off-road conditions.
  • For deep mud, deep snow, sand and other boggy conditions, even more pressure reduction can be used (but with caution).
Warning Icon.pngWhen tyre pressures are reduced (for any reason), vehicle's top speed should be limited to approx 50 km/h / 30 mph on tarmac roads, or ~ 40 km/h / 20 mph on gravel roads. Otherwise, the tyres might overheat and disintegrate prematurely!
Dependency of tyre pressures on axle load
  • Required / recommended tyre pressure generally also changes with load (weight on the axle).
  • The heavier the load, the more pressure (air quantity in the tyres) on that axle is required to carry it.
  • For almost any vehicle, manufacturers specify different tyre pressures for different loads (for example - driver only, full passengers with cargo, towing a trailer, loaded cargo bay, etc.).
  • For Jimny (as far as it is known), Suzuki has not specified different tyre pressures for empty and laden conditions.
  • That is probably because the vehicle has such a small load rating (cca 300 kg at most - roughly 150 kg per axle!) that it does not matter that much.
Specific tyre pressures for Jimnys
  • So, for a Jimny, the factory recommended on-road tyre pressure for stock size tyres (205 / 70 / R15) is 1,6 bar (23 PSI) front and 1,8 bar (26 PSI) rear.
  • Some Jimny owners even the tyre pressures to 1,7 bar on all four tyres, for simplicity.
  • When driving on gravel roads or general off road, it is completely fine (and even advisable) to reduce the tyre pressure by 25-30% to 1,25-1,15 bar (17 - 18 PSI).
  • The difference in ride quality is astonishing, while the traction is significantly improved.
Effect of tyre size on tyre pressures
  • When using tyres which are larger than stock size, all (both on-road and off-road) tyre pressures should be reduced from the above written numbers.
  • Because it is the air itself (air molecules) that carries all the weight, the concept is to always have the same amount of air molecules in the tyre for certain road and load conditions.
  • The larger the tyre, the more air molecules fit inside for the same tyre pressure.
  • So, to achieve the presence of the same number of air molecules in the tyre regardless of tyre size, a lower tyre pressure has to be used with a larger tyre.
  • There is no simple formula for calculating how much the on-road (and implicitly off-road) tyre pressure should be reduced with certain larger tyre sizes.
  • This topic is still under investigation.
Measuring and inflating tyre pressure
  • It is compulsory to carry a good quality tyre pressure measurement tool, and very desirable to have your own 12V air compressor.
  • You can inflate your tyres at gas stations (their equipment is much quicker than your own compressor), but you generally should not trust the pressure measurement instruments at gas stations, as they could be wildly inaccurate!
  • Trusting that a publicly (ab)used pressure measurement instrument at a gas station is accurate is like trusting that a prostitute has no STD.
  • There are local exceptions of course, but this is a general rule.
  • Deflating tyres can simply be done by the stone age era method - using sticks and stones.
  • There are various cheap and expensive tools which enable faster and/or controlled tyre deflation.
  • The quality and usefulness of those tools vary widely.
  • Since tyres on Jimnys are relatively small (compared to most 4WD vehicles), the practice has shown that using the stone age method is generally sufficiently fast.
  • In other words, the time savings provided by various tyre deflation tools are hardly worth the cost and effort on such relatively small tyres.
  • Employing a passenger to deflate two tyres in parallel with you (using sticks and stones) is cheaper and faster than using the tools.
  • After several inflation-deflation iterations, you will be able to roughly calculate how much time you need to deflate your tyres from the on-road tyre pressure to your typical off-road tyre pressure.
  • For example, one experience says that it takes approximately 25 seconds to reduce a 205 / 75 / R15 tyre's pressure from 1,7 bar to 1,20-1,15 bar.
  • This way, you won't have to check the tyre pressure several times with the pressure measurement tools when deflating each tyre.
Wheel balancing
Jimnys, as all vehicles with solid front axle suspensions, are susceptible of developing a "death wobble" vibration at a certain speed range.
Note Icon.pngRead more about death wobble in Death Wobble wiki article.
Since wheel disbalance can easily cause death wobble, you need to take additional considerations in order to balance your wheels properly.
You can educate yourself about wheel balancing issues at the dedicated chapter "Wheel balancing" of the above mentioned death wobble wiki page: Wheel balancing
Page last edited on 27/02/2017 by user Bosanek
