Expedition Jimny Project
- Safarisan
- Visitor
- Decalwizard
- Visitor
Everything on the roof is bolted firmly to the rack so it wont move..
Inside the car the fridge and other boxes ate all held in place by bump stops and heavy duty ratchet straps..
The Jim handles pretty well considering the weight on the roof, I try and keep as much of the heavy stuff low down so it counter acts the top end weight
- Decalwizard
- Visitor
Here goes..
The Rotopax Fuel can(s) finally were fitted to the rear wheel on a special bracket that was fabricated. The Rotopax bracket can carry a 1.75 Gallon and a 3 gallon pack together and can be locked with the locking Rotopax bracket
I also got round to fitting the micro shovel on the rear door with the Quick Fist Brackets (No Jokes)
The Awning was removed and fitted to the passenger side and the tent spun through 180 degrees so I could fit the snorkel
The roof tent outer cover has been replaced with a brand new Tuff-Trek Cover
The Winch Plate & Winch are now fitted
All the brakes have been replaced (Drums, Shoes, Pads & Disks) and the suspension now lifted 2" & the front and rear axles have been trussed for extra strength.
I have also fitted the Tyre Dog Tyre Pressure monitoring system (To the right of my Satnav)
I also managed to locate some super strong storage boxes to fit where I used to carry the fuel cans
Other than the purchase of a T-max compressor, a new awning room & a solar panel that is pretty much it. Its now time for the Jimny to pay me back in enjoyment..
I will pass by every now and then for a browse, Its been fun.. Hope you all keep enjoying your little Tonk's
DW
- 2014Nathan
- Visitor
- Decalwizard
- Visitor
The winch was a cow to fit but it may not be the same for all years of Jim, My winch had the clutch lever right at the top and it hit the top cross member so I had to strip it and re-locate the lever lower down
- 2014Nathan
- Visitor
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
Above is from experience, on the rare occasion I use my winch have had no problems on this Jim or the last. Friends use same single std battery setup too.
Gary
- 2014Nathan
- Visitor
funkyjimny wrote: You are fine wiring the winch to the single standard battery as long as the engine is running when in use, if using it for extended length of time let it have a break and the battery recharge a bit, if you want to do some regular heavy winching use two batteries, one specific to the winch with a heavy duty split charge system designed for winching.
Gary
That's ok then iv got a slightly bigger battery for the standard size holder so I'll try it with just the one see how I get on then. It's only there if I need it for self recovery / move fallen trees not going out and planning on using it Will Hopfully have it fitted up this weekend
- Decalwizard
- Visitor
I am running mine of a single bigger High Cranking Exide battery, as said above for emergency rescues you will be fine as long as the engine is running and you only operate the winch in small bursts. Ideally a second battery is always the best option then you dont risk not being able to start the car
- idiotmobil
- Thank you received: 118
Decalwizard wrote: My final update of the Overland Jimny as I am busy working on another project, I thought it was only right to finish the thread I started before I leave..
Here goes..
DW
they look like tabacco storage boxes they use in the factorys ive got a load of then but don't think I have any lids theres a place in millbroke Southampton that's sells them im sure they were only 4 pound each
JIMNYLESS
- idiotmobil
JIMNYLESS
- Decalwizard
- Visitor
