BigJimnyMeet 2024
Tyre pressures
- Cremator1
- Visitor
03 Feb 2019 09:33 #202420
by Cremator1
Tyre pressures was created by Cremator1
Hi all just fitted 205/75 /15 At3 general grabbers what pressure do you find best to run them at many dawn
- Thank you received: 305
03 Feb 2019 09:49 #202423
by sniper
Replied by sniper on topic Tyre pressures
Try a few is my advice..
20psi, 22psi and 24psi would be a good spread. see what suits you and how the car responds. Anything above 25psi makes my AT's too stiff and it bounces off speed bumps and potholes.
If you take the time to try a few different pressures, you will find a sweet spot where you are happiest.
sniper
sniper
03 Feb 2019 09:52 #202424
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Tyre pressures
Good advice from Sniper.
I varied mine a bit to find what worked best for me. I run Hankook Dynapro ATM 195/80 R15 and find 22 psi front 24 psi rear gives a nice ride. Anything higher and it feels skittish and bouncy.
- Cremator1
- Visitor
03 Feb 2019 09:56 - 03 Feb 2019 09:56 #202425
by Cremator1
Replied by Cremator1 on topic Tyre pressures
Hi guys ok will start with 20psi at mo got 25 in and feels a bit bouncy is that 20psi all round
Last edit: 03 Feb 2019 09:56 by Cremator1.
- Thank you received: 1755
03 Feb 2019 10:04 #202427
Replied by Lambert on topic Tyre pressures
I have just swapped the tyres between my 2 and when measuring the tread depth found that the 26 psi I had been running in the back was taking the centre out of the tyres. I'm now at 23 psi front and back and the ride is much improved. I have no back seats and only rarely have a full load for any length of time, mostly running empty.
- Cremator1
- Visitor
03 Feb 2019 10:06 #202428
by Cremator1
Hi lambert are they the same size as mine
03 Feb 2019 10:18 #202429
205 70 15 96 h. The size is less important than the load rating which is a code expressed by the 4th number in the sequence I just posted. The higher the load number the less pressure you need for the optimum performance of the tyre. An all terrain will probably be something like a 100 or 102 and will need less pressure than my road pattern. But it also depends on the weight of the specific vehicle, Ermintrude is relatively light weight and needs less air than one with winches or timber storage decks in the back etc.
- Cremator1
- Visitor
03 Feb 2019 10:35 #202431
by Cremator1
Mine are 97t and don’t carry anything in back just standard other than steel rims
03 Feb 2019 12:59 #202443
Then as suggested start with 22 or 23 and go from there. You're wanting it to feel smooth but not floaty. If they're too soft it will squirm an wobble over bumps and holes if they're too hard it will crash and bounce. You're wanting the happy medium.
- Cremator1
- Visitor
03 Feb 2019 16:52 #202453
by Cremator1
Hi ok put 22 in them will try that also fitted a steering damper and when turning wheel at low speed you can hear it creak when turning the wheel
03 Feb 2019 17:36 #202458
Sounds about right.
- Thank you received: 650
03 Feb 2019 17:59 - 03 Feb 2019 18:00 #202462
Replied by jackonlyjack on topic Tyre pressures
Steering damper just ignore the squeak/creak/grown noise mine makes them all
Last edit: 03 Feb 2019 18:00 by jackonlyjack.
Time to create page: 0.159 seconds
